Results 1 to 10 of 14
Thread: RG 174 cable with SMB female connector to USB
    Apr 2005
    My work deals with GPS tracking units which are installed in vehicles, but I had to the idea to connect a USB connector to one of the GPS antennas so that I can hook it up to my laptop and use Streets & Trips.
    The connector on the GPS antenna right now is a SMB female and I want to convert it to a USB. Is this possible? Would I need any firmware/software, etc? (new to this stuff)
    I know that USB has +5v, D+, D-, GND...so we figured that +5 on the USB will go to the antenna supply, connect D+ with a capacitor to ground, then D- with a capacitor to 5v, and GND on USB to GND on the antenna.
    I also scanned the instruction sheet for the antenna if it has any other useful information. Thank you very much!
    Nov 2004
    Netherlands
    You can't.
    This antenna is only an active antenna. (power supply needed for the active part).
    You WILL need a receiver in order to use it. Most current receivers are based on the Sirfstar II chipset, like e.g. the BU-303. Older ones are based on e.g. Rockwell chipsets.
    This receiver converts the (1.3Ghz if i'm right) signal into a RS232 compatible signal. (With a MAX232 or something simular to make the levels PC-serial compatible).
    Additional, a USB->Serial convertor might be included, mostly based on the Profilic chipset. Usefull for pc's without serial
    Anyway: get a GPS receiver. I have a BU-303 and replaced its internal antenna with an external (waterproof) one, just like the one you have. But without additional electronics, its useless.
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    im only it were that simple, then GPS would only cost $20!
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    DJSmiley is right. From what you are saying, you only have an antenna. You still need a reciever to convert all the data from whats coming off of the antenna.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Apr 2005
    Thanks for the information.
    Where can I go abouts and buy this receiver?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    depends on which one you want, garmin, ublox, trimble the list goes on.
    肚子笑痛了
    S60 Install
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    RF solutions do some nice OEM GPS modules for abotu £33.
    But some require a bit of work to add serial or USB conenctions. I think RF solutions fo serial and USB ready one s that look quite good from their specs. Should be better than most USB mouse type GPS solutions,.
    Or you can wait until jcdillin and I do the dead reckoning GPS system - that is gonna rock!
    Apr 2005
    Well, this isn't really needed, just wanted as I have a laptop I don't really use so I thought it would be neat to hook up GPS to it. We also deal with GPS units at work, so I most likely can order one up and get it for a half decent price. I will look into it tomorrow.
    May 2003
    Miami, FL
    DR all the way
    肚子笑痛了
    S60 Install
    Mar 2004
    Bristol
    Quote Originally Posted by jcdillin
    DR all the way
    hell yeah!!
    you can build an oem type system with separate antenna for a about £33 (module) and £14 (antenna). That works out cheaper than a BU-303!!!
    but quite frankly, DR is where it's at!
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 01:55 AM
  2. USB video input cable
    By Custommx3 in forum Input Devices
    Last Post: 05-04-2004, 01:51 PM
  3. where can i find a USB cable like this one?
    By jusatry in forum General Hardware Discussion
    Last Post: 04-11-2004, 03:24 AM
  4. Lilliput USB cable
    By Custommx3 in forum LCD/Display
    Last Post: 03-20-2004, 06:12 AM
  5. USB gps mouse , max lenght cable
    By BOND007BE in forum General Hardware Discussion
    Last Post: 12-17-2003, 06:54 PM
