Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: winxp thinks my USB GPS receiver as mouse after cold boot (start up)
  1. #11
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    If you want to fix it for good, search for sermouse.sys (in the windows dir) and rename it to something else (sermouse.sys.bak)
  2. #12
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by aoLhaTer
    Will I still be able to use the mouse? (USB mouse in the car and PS2 when I take it inside) - Thanks.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  3. #13
    Dec 2004
    Bay Area, CA
    I did what aoLhaTer suggested and renamed the serial mouse driver file. No more jumping mouse (at least as far as I could tell) and everything works just fine. What is funny is that my carputer booted right up with no problems. Usually I have to push the restart button a few times to get it going....
  4. #14
    Mar 2003
    Rohnert Park, CA
    sermouse.sys is the driver for..you guessed it, a serial mouse. USB and PS2 mice shouldnt be effected
  5. #15
    Dec 2004
    Bay Area, CA
    Okay....It did not work...When I started the computer this morning the jumping mouse was back again. I checked the "semouse.sys" which I had renamed and it turned out that the XP had automatically reinstalled it for me! I guess there was no point renaming it again if XP was going to reinstall it.
    So I went into the registery to check on the fix that I had applied before (see above post by ret). I noticed that fix had also been changed back to its original (last number had become 3 instead of 4). Probably it had happened when I removed the craputer to install the XM radio. So I again changed the last digit from 3 to 4.
    It now seems to be working again as I rebooted and the jumping mouse was gone. We shall see if that fix will hold when I start the carputer on the way home tonight.
  6. #16
    Mar 2005
    I think you can disable the auto restore so it doesn't restore the files, but don't ask me how!
  7. #17
    Dec 2004
    Bay Area, CA
    Several boots and still no jumping mouse. My guess is that because of the change in the PC configuration, windows must have reset the registry when I took it out of the car. After I applied the registry fix again, it looks like it is permanently fixed. I just have to remember to do it every time I take the computer out of the car.
  8. #18
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Quote Originally Posted by ret
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\sermouse]
    "Start"=dword:00000004
    there should be no blank between Servic and es!!!!
    So did you just put a space in the name "services" or did you change the value to 4?
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  9. #19
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by LinuxRacr
    No space. Just change the value to 4 Mine is working fine ever since.
  10. #20
    Jul 2003
    Dallas, Texas
    Yup, that's what I did. No more issues!!
    Current build! Here
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 06:53 AM
  3. GPS Receiver - USB -vs- Serial
    By Daz in forum GPS
    Last Post: 06-24-2003, 05:56 PM
  4. simple soft to test USB GPS receiver
    By felix99 in forum GPS
    Last Post: 10-08-2002, 03:23 PM
  5. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 03:54 PM
