Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: winxp thinks my USB GPS receiver as mouse after cold boot (start up)
  1. #21
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have found that the registry 'fix' gets 'unfixed' under certain occasions. I have now exported the reg key to my desktop. Next time it happens, solution is a click away
  2. #22
    Aug 2005
    Quote Originally Posted by ret
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\sermouse]
    "Start"=dword:00000004
    there should be no blank between Servic and es!!!!
    Can someone explain to me where I put this?
  3. #23
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you have to use the registry editor (regedit) to change it in the registry.
    I you have to ask where to put it. I would suggest you don't do it as you have no idea of registry editing and if you start messing with the registry without knowing what you are doing you can really mess up yuor OS install.
  4. #24
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Enforcer
    Why don't you send him your file?
  5. #25
    Jul 2005
    BC, Canada
    I believe the full fix for this guys is to go to your C:\WINDOWS\system32\dllcache
    and delete or rename your sermouse.sys file that's where it recovers the files from if it sees an issue, if it doesn't have that file in order to recover, it wont, then delete or rename the one in system32, i haven't had an issue since, but had the issue with doing the regedit fix, after a few boots it came up as a sermouse again, so the file thing worked great so far
  6. #26
    Aug 2005
    Thanks for the info.Your right I probubly shouldnt mess with the regisrty but how else wil I learn?
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by happs
    Read up on registry editing, especially the bit about backing up the registry before you do anything.
    Use regedit, find the location above, have a good long look at it to make sure it is correct. Make no changes
    Back up the registry
    do that two or three times and then when you are confident or feel lucky make the change.
  8. #28
    Feb 2005
    netherlands/opmeer
    GPS goes grazy (floating)
    just for those who don't want to hack there registry, the floating mouse problem
    can be solved with a plug and play blocker, it can be downloaded here
    http://www.stentec.com/software/pnpblocker.html
    it blocks the detection of the gps as a mouse.
    greetz
    opmeer. Netherlands
    Renault Laguna
    platform win xp, navigon europ. road runner
    100%
  9. #29
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    tried the reg edit method, but I have no 'start' to midify.
    cant we just have a reg.inf to download or something this problem is driving me mad, and I buried all the cables, so if I unplug the usb end the mouse disapeers in device manager before I geta chance to disable it.
    deleting the sermouse wont work SFC restores the damn thing.
    its a joke this MS fsckup, it should be able to see its gps data etc
    Lez, more widely known as flez1966
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by lez
    [g8tk33per mode = on] **** you, you retard, read the thread again properly, and try to talk properly. You have to add the "Start"=dword:00000004" to the registry key, not modify it.[/g8tk33per mode]
    Once you have created just export the key and put the reg file on your desktop for future use.
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 06:53 AM
  3. GPS Receiver - USB -vs- Serial
    By Daz in forum GPS
    Last Post: 06-24-2003, 05:56 PM
  4. simple soft to test USB GPS receiver
    By felix99 in forum GPS
    Last Post: 10-08-2002, 03:23 PM
  5. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 03:54 PM
