Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 43
Thread: winxp thinks my USB GPS receiver as mouse after cold boot (start up)
  1. #31
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    reg editing is not my best skill.
    but the problem was most annoying.
    If I delete the sermouse.* in windows, SFC puts them back.
    If I unplug the gps so I can move the mouse, the 'ballpoint' mouse in device manager gets removed before I have a chance to disable it.
    I did not know you could add keys to the registry with regedit that simply.
    Now I will go and buy a new keyboard so you can see me talk properly....
    Lez, more widely known as flez1966
  2. #32
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Quote Originally Posted by Speedsterworld
    I believe the full fix for this guys is to go to your C:\WINDOWS\system32\dllcache
    and delete or rename your sermouse.sys file that's where it recovers the files from if it sees an issue, if it doesn't have that file in order to recover, it wont, then delete or rename the one in system32, i haven't had an issue since, but had the issue with doing the regedit fix, after a few boots it came up as a sermouse again, so the file thing worked great so far
    I couldn't find the dllcache folder on my computer.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  3. #33
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    just go into device manager.. and right click on the Microsoft Serial Mouse.. and cick disable... no more issues...
  4. #34
    Jul 2003
    So much easier!
    Current build! Here
  5. #35
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by strohj
    With my RandMCnally GPS Serial Rx, I had to do that 3 times each time the OS was installed and it stopped it.
    I'm about to try the registry fixes.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  6. #36
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Quote Originally Posted by LESLIEx317537
    Same gps Im using, and I get this same problem all the time, ugh....
    2000 Sunfire build 100%, or is it ever really 100%?
  7. #37
    Jan 2002
    Long Island, NY
    I just did the reg fix last night for my RandMcnally serial and it seemed to work. The device manager had a serial mouse but a ! in it and the GPS RX still worked and I haven't had a jumpy mouse yet.
    I just got my new BU355 with both a Serial and USB cable set. I'm testing it now with hibernation etc...testing xport etc..I wanna go USB if I can.
  8. #38
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by CavityCr33p
    Registry fix or renaming the file eventually gets reversed (if you disconnect the GPS wire and reconnect it, windows somehow chnages the registry and/or reinstalls the driver) What finally worked for me was going to device manager and disabling (not deleting) serial mouse.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  9. #39
    Jan 2002
    Long Island, NY
    Quote Originally Posted by Zebelkhan
    What do you mean disconnect the GPS wire?
    The RandMcNally has a PS2 connection for power and a RS-232 connection for data to the serial port.
    The RandMcNally is serial port and the PC doesn't know if it's connected or not like a USB GPS.
    I don't see how it would change the registry if you unplugged the unit. Maybe if it was USB, then I could see...
    I have to check my new BU355 via USB and see if that changed the registry entry back.
  10. #40
    Dec 2004
    Bay Area, CA
    I meant unpluging it....
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 01:32 AM
  2. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 05:53 AM
  3. GPS Receiver - USB -vs- Serial
    By Daz in forum GPS
    Last Post: 06-24-2003, 04:56 PM
  4. simple soft to test USB GPS receiver
    By felix99 in forum GPS
    Last Post: 10-08-2002, 02:23 PM
  5. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 02:54 PM
