what kind of speakers do you have? how loud are you playing it? what are your system specs?
I use iguidance and have no probelms, some times i get a sub thump from boices but thats it.
I have searched all the other forums and cannot find anyone else with this problem
I installed media engine and then i installed iguidance 2.1, when ever the voice for the gps comes on it's not clear(cracking), I then uninstalled media engine and tried frodoplayer, but still the same problem
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
Give it a lozenge. Should fix it right up.
On a serious note, check your volume settings. You might just need to turn down wave, or cd volume. I'm not sure. Does FP and iGuidance use the same settings?
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
they both have there own volume controls, I have fp set at 98 % and have tried adjusting the volume level in iguidance, but at any level on iguidance it still crackles
If you don't like the iGuidance voice, then you can change it by downloading NaviVoice and using its Config utility![]()
