Results 1 to 10 of 12
Thread: New Road Angel 2 GPS Camera Det + Mapping?
    Jan 2004
    Can anyone help? Please..., Im after some mapping software that is compatable with the New GPS Road Angel.
    It apparently can be used as a route finder too..!
    BUt cant seem to find the right map software..
    Autoroute uses com 1 or 2 and the road angel is USB...
    Any ideas
    looking for voice guidance in the software too...
    Much appreciated
    Elsewhere
    According to the specs of the unit, there is no GPS interface witht eh Road Angel to the PC. The USB is only used to update it's speed camera database from a PC.
    http://www.blackspot.com/products/ro.../indexmain.htm
    How about the Wiki?
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    the GPS would be connecting to a type of flash memory for the maps to be updated and would actually be able to use the GPS part of the road angel.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I thought the Road angel was capable of being used as a GPS receiver by outputting its current speed, heading, and location to the PC via USB...
    Then a serial port driver something like the Prolific one would create a virtual com port and output the signal to that so progs like D3 can use the data stream from the Road Angel.
    Jan 2004
    using new road angel gps
    http://www.roadangel-direct.com/faq.php#eighteen
    they say that it can be done...
    see bottom of their faq...
    where can i get the prolific virtual com port thing from, need to look into this,,.,,
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Re-post of one of my posts on digital-car.co.uk, I cannot guarantee it will work but might help you on your way. The 'can be used as GPS' might refer to the old one which has a serial port.
    Quote Originally Posted by StevieG
    I've downloaded the USB road angel drivers and had a look round the INF files...
    They use components from here:
    http://www.ftdichip.com/
    And the exact driver that the Road Angel is using is this:
    http://www.ftdichip.com/FTD2XXDriver.htm
    Which is an API mode driver to allow the road angel developers to access the COM port data without exposing a COM port.
    DON'T BLAME ME IF THIS DOESNT WORK... BUT
    If you uninstall the supplied driver and use the one from this page:
    http://www.ftdichip.com/FTWinDriver.htm
    The road angel will expose a COM port. Switch GPS mode to ON, on ther road angel unit and test it out using this utiility from the manufacturer of the GPS unit inside the road angels homepage...
    http://www.holux.co.uk/Downloads/GpsViewer.exe
    SO, now you've done this and (assuming it works) want to update the Road Angel you would either need to uninstall these drivers and re-install the Road Angel supplied ones after turning GPS output off (then vice versa when you want to use GPS), or after turning GPS output off download the Serial Road Angel software:
    http://www.blackspotinteractive.co.u.../roadangel.exe
    And use that to update the road angel... However this might A) Work or B) Not Work or C) Corrupt your Road Angel - I say that because when I used a 3rd party serial-usb adapter with the road angel the GPS worked but when I updated it, it corrupted the road angel - luckily when I used the direct serial the software fixed it though
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Jan 2004
    road angel gps
    i have spoken directly to the manafacturer who has assured me the road angel i have works with gps, but they say that it dosnt work with the usb port, thats just for the updates.
    They say i just need a serial cable and the data NMEA or something is available at 9600 baud rate, its been tested by them using autoroute 2003 and infomap...
    They didnt test it with destinator but thats what i really wanna use.
    Where can i get my hands on a serial cable and destinator trial?
    Aug 2004
    On the edge!
    Can a Snooper S3 output GPS locations to PC too?
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by TurbodieselMan
    Does it have a 9-pin serial port on the back? If you are not sure, have you got a picture of the back/part where the interfaces are?
    It will be outputing NMEA sentances at 9600 baud, it will work therefore with Destinator 3, Road Runner's Mappoint support, pretty much everything really.
    Jan 2004
    gps and road angel
    its a 9 pin round seriel connection, Where can i get hold of mappoint or destinator 3 sdk trail or something?
    thanks
    Im in Sheffield UK BTW and will have to let me know when the next car meet is..
  1. gps enabled camera
    By john_draws in forum GPS
    Last Post: 10-11-2007, 07:33 PM
  2. Replies: 81
    Last Post: 05-15-2005, 04:53 PM
  3. why is my backup camera not working with my capture card?
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-17-2005, 02:52 PM
  4. CHEAP BUYS!: Deluo GPS and Wireless NightVision Camera!
    By DLe in forum Classified Archive
    Last Post: 10-07-2004, 08:34 PM
  5. GPS Speed camera locator
    By Glyn in forum GPS
    Last Post: 11-13-2002, 12:01 PM
