Results 1 to 10 of 13
Thread: GPS device diagnostic
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Question GPS device diagnostic
    I got my Rayming MR-350 yesterday. It has USB-to-serial adapter and looks like a COM port to XP. Now, the problem is, the device doesn't seem to work properly - it is not detected by enclosed software (GPSInfo) and when I connect to that COM port on 4800 baud, there is a lot of seemingly random binary garbage coming from it
    Is there some software that can check and properly setup a GPS device?
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You installed a driver with the USB-serial adaptor, right? Right click "My computer", select properties and go to device manager. Look at the COM ports. Your USB-serial adaptor ought to show up there and you should be able to see what com port it is on. (Sorry, rereading your post it looks like you may have done that but I'm not sure so I'll leave the instructions in).
    Beyond that, XBrady's earlier version of GPSsecure had a little window that you could see the NMEA strings streaming by and it shows the satellite locks. Maybe PM him for a version 1.0 of it.
    Want to:
    Apr 2005
    Seattle
    Quote Originally Posted by Bugbyte
    I found it - the thing was sending data in SiRF binary format at 38400 baud rate. Still does SiRFDemo did a good job detecting the protocol, but cannot switch it to NMEA.
    FLAC Marvin Hlavac's Avatar
    May 2005
    Hmm, I read your other post where you mentioned MS Streets & Trips. S&T will have hard time with 38400 baud rate. Try GPS Gate GPS Gate might just be able to read the signal coming from your receiver, and it may output signal understandable by your S&T.
    It will not cost you anything to try, and it may just work. If it does, the added benefit of GPS Gate is that you will be able to use even several GPS software applications with your one receiver.
    MR-350 is advertised as supporting NMEA. I'm not sure why it would be outputting SiRF. I'm assuming you do have the correct cable and driver software installed. You mentioned you couldn't switch from SiRF to NMEA in SiRFdemo. If just clicking on "Switch to NMEA protocol" doesn't work, I would try clicking on "Synchronize protocol & baud rate".
    Apr 2005
    Seattle
    Quote Originally Posted by Marvin Hlavac
    Hmm, I read your other post where you mentioned MS Streets & Trips. S&T will have hard time with 38400 baud rate. Try GPS Gate http://franson.com/gpsgate/ GPS Gate might just be able to read the signal coming from your receiver, and it may output signal understandable by your S&T.
    Yes, it looks like a very nice piece of software I didn't find however any mentioning of the SiRF binary support.
    "Switch to NMEA" has no effect and "Synchronize" syncs back to 38400 / SiRF binary It appears to me that none of the SiRFDemo commands are passed to this receiver, even those in "Poll" menu add nothing to received messages.
    May 2005
    Earlier I read that the 350 needed some special cable. Do you have that?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I know nothing about the GPS chip your using but I know that some have firmware updates that you can apply.. It's possible that that may solve some of your issues...
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Apr 2005
    Seattle
    Sure I do, it's PS/2-like (no clue what's the right name for it) to USB pigtail adapter.
    Apr 2005
    Seattle
    Quote Originally Posted by IntellaWorks
    It has SiRF Star III chip, it's new and I haven't seen any updates for it yet
    Jun 2004
    NH
    GRRR man, that sucks. Have you tried any other GPS diag software ??
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. Gps Diagnostic
    By 4u2n in forum GPS
    Last Post: 09-06-2007, 03:01 PM
  3. Replies: 6
    Last Post: 01-21-2005, 03:12 PM
  4. Replies: 9
    Last Post: 10-25-2004, 02:34 AM
  5. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
