Results 1 to 10 of 15
Thread: Accuracy of Rikaline 6010
    Raw Wave justintime's Avatar
    Apr 2005
    Accuracy of Rikaline 6010 (or is it iGuidance?)
    I recieved my Rikaline 6010 from eBay today, and have been playing around with it (using my laptop for now).
    Im using iGuidance 2.0
    I'm not experienced at all with GPS technology, so I don't know if this is normal: seems like accuracy on main roads (interstates, etc.) is dead on -- very cool. On secondary roads (like the roads in my subdivision, and my neighboring subdivision too) the icon is offset from the main road substantially. iGuiadance thinks I am offroad! I would say it is off by 200-400 feet or so. The offset is always to a 'side', so it appears I am not even on the correct road (!)
    Is this normal? This would certainly seem unusable for regular driving (unless on a main road, duh!)
    Thanks for any pointers.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    That's not normal - i.e. it should be dead-on
    How many satellites do you show and how many is it connected to (i.e. if you go to the GPS status in iGuidance, it will show something like 5/9 or maybe 9/12 or something liek that depending on where you are). If you are not "seeing" enough satellites like just 1 or 2, then this may be the reason - I am speculating...
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    2000 Mitsubishi Eclipse GT
    - V6 216hp
    - KYB-AGX adjustable struts
    - Konei Alloy 17" rims + Pirelli P-Zero's
    - AEM slotted brakes
    - AEM CAI
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    iguidance should "snap" you to the road anyways....
    rebuilding carpc... kinda..
    FLAC Marvin Hlavac's Avatar
    May 2005
    You may check the software that came with your GPS receiver if it has settings that would allow you to change Map Datum. The setting should be set to WGS84.
    Apr 2005
    Forgot to mention that. It was typically showing 5/9 satellites.
    I'm guessing the issues here is either one of two:
    1) iGuidance maps for my region is not accurate, or
    2) Receiver is not working properly (I doubt this is the issue, since it works perfectly on main roads)
    Could it be that the mpas for my region are not accurate placed? (roads are offset, etc.?)
    Quote Originally Posted by sxt173
    2002 Honda CR-V
    Apr 2005
    Hi Marvin.
    The 6010 only comes with a driver. As far as I could tell, there was no way to tweak this unit. Maybe I'm wrong... does anyone know if the 6010 can be 'tweaked' or configured?
    Quote Originally Posted by Marvin Hlavac
    2002 Honda CR-V
    Apr 2005
    ALso, my 6010 included a CD, but this did not have any sort of diagnostic tool
    I keep on hearing about GPSinfo.exe. I googled for it, but does not seem to be a freely available tool.
    Any other tools that could help me diagnose the problem?
    Thanks!
    2002 Honda CR-V
    Nov 2003
    CT
    the drier is all you should really need. its the prolific usb to serial. it just creates a vitrual com port so it can stream the data. as for the maps...they could be off. try and get your hands on 2.1. they have updated maps
    Apr 2005
    So, it *is* possible that the maps are off by a few hundred feet? I hope that's all it is, as I don't want to have to return the Rikaline receiver
    Here is a screenshot of what I see when I stop at an intersection in a smaller subdivision. As you can see it is offset by a few hundred feet. Is this something that needs to be calibrated? Seems to work OK in the main roads, but offset in secondary roads...
    2002 Honda CR-V
    Apr 2005
    Update
    I 'geocoded' my street address using an online service, and the Longitude/Latitude values yielded through geocoding are DIFFERENT than the ones yielded by the GPS using iG. It appears that the geocoded values are correct, because when I input those in iG, it hones in on my address in the map.
    I think the natural conclusion here is that the GPS receiver is not giving me an accurate reading at all. Is this conclusion correct?
    Can something be wrong with it? Any way to 'calibrate' it?
    2002 Honda CR-V
  1. Replies: 8
    Last Post: 05-08-2005, 10:52 AM
  2. Replies: 5
    Last Post: 04-09-2005, 05:37 PM
  3. Rikaline 6010 Strange Fault
    By clkraj in forum GPS
    Last Post: 01-22-2005, 08:24 AM
  4. My BU303 vs. Rikaline 6010 Review
    By Nico3k in forum The Review Palace
    Last Post: 01-05-2005, 11:42 AM
  5. rikaline 6010 Locks up/reboots machine
    By Lord_Pall in forum GPS
    Last Post: 12-30-2004, 02:46 AM
