Results 1 to 10 of 15
Thread: Globalsat BU303 sat lock
    Feb 2005
    Unhappy Globalsat BU303 sat lock
    Hello all.
    Installed car pc ok, but sat nav unreliable. The BU303 keeps loosing sat lock for long periods of time, but when it does lock on I get up tp 10 sats showing.
    I read some months ago of a simular problem that was traced to a dead batery inside the BU 303, which when removed cured the problem. I have searched but cannot find the thread. Can anyone help with the problem or point me to the the thread......Many thanks.
    Jan 2004
    Jersey/NY
    Feb 2005
    Wink
    Many thanks, that is exactly what I was looking for.
    Feb 2005
    Having read the thread to the end, I am more confused than ever
    Should I remove the supercap or not? Is this likely to cure the problem I am experiencing? Can anyone recommend an alternative that will work reliably?
    Please, please, help!!!!!!!!!!
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by galant
    Try removing the supercap and see if things improve. Somehow I believe that many problems people are having with their BU-303 are because of the housing not being waterproof.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    I have my BU-303 on the inside back window no tint. It works fine but then it will lose all the sats and I get lost and then way later it will pickup.
    Same results outside the car
    brand new today ?
    what do I do?
    thanks
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    Low Bitrate happpyg's Avatar
    Feb 2005
    Bunbury, Western Australia
    Try changing the refresh rate of your LCD. Anything above 70Hz makes mine lose locks (if it even manages to get one). Below that it works fine!
    Semperon 3200+/512MB/ Seagate SATA2 120GB
    10.2" Xenarc/ Netgear USB Wireless
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    http://www.happyg.mine.nu/carpc/index.html
    May 2005
    Woodstock, GA
    Quote Originally Posted by happpyg
    Really. I think raising tire pressure and topping off the coolant would fix the problem.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Feb 2005
    Have you got one?
    It actually makes perfect sense if you know anything about electronics & RF interference.
    Do some research before you post, i'm not the only one that had this problem and - IT WORKS! Can be replicated over and over again, change rate - lose lock, change back & get lock again!
    bu-303 ... noticed something
    What can cause radio interference with GPS signals?
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    FLAC djmickyg's Avatar
    Feb 2004
    i took out that crap cap months ago and the things never worked better..
  1. Replies: 8
    Last Post: 05-08-2005, 11:52 AM
  2. Replies: 12
    Last Post: 09-23-2004, 03:00 PM
  3. Replies: 2
    Last Post: 07-09-2004, 04:35 AM
  4. Replies: 11
    Last Post: 01-31-2004, 08:57 PM
  5. Replies: 7
    Last Post: 04-03-2003, 12:12 PM
