Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 66
Thread: Attention Newbies! Everything (almost) you want to know about GPS (Part 1)
  1. #41
    Mar 2006
    Street Atlas Delorme
    I have Street Atlas The thing that stinks about it is you can only add 200 addresses to your address book. I drive a truck and need more. I know I can buy street atlas plus but have already spent 89 bucks on the first one.
  2. #42
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    I plan my route inside with streets and trips on my laptop, then carry it to the car and put it in it's custom holder (like the police use, I can't think of the word! lol) and plus in the usb 353 and it works great for getting me where ever I need to go. I plan the route and when I get in the car I don't even need to touch it ....but I realize this doesn't work in everyones situation
  3. #43
    Apr 2006
    S&t 2006
    Hey, I just picked up S&T 2006, it now does turn-by-turn voice directions, and, you can put it into 'Night Mode' where it's green-on-black... (I attached a pic of it to better illustrate this)
    I've yet to try 'Direction Guidance' (OSD / Voice directions).... Since I just got/installed it.... haven't even had it in the car yet
  4. #44
    Low Bitrate Queenambeach's Avatar
    Apr 2006
    I have Streets and Trips 2006 and I must say it is great. turn by turn directions, 4 different map views (including night view) and the POI directory and search feature is by far the best!
  5. #45
    Low Bitrate uptpilot's Avatar
    Jun 2005
    Oklahoma City
    Question S&t 06
    I have a Xenarc 7" LCD and I run the video card at 640x480. I run it with a form factor PC mounted in the trunk with the LCD mounted in the dash. It works very well. For software I currently use iGuidance, but I have several issues with it.
    Would anyone think that S&T 2006 is a suitable replacement for iGuidance? can it be highly customized to be run entirely from a low resolution touchscreen? The GUI would need total replacement to accomodate big buttons.
  6. #46
    May 2005
    Via Michelin
    I'm using viamichelin(searching for a better app) here are some pros and cons:
    Pros - Very userfriendly, 3d view
    Cons - Hard to get updates, before u can use the touch-screen friendly u needa fil in ur detination etc without a touch-screen friendly gui, it brings you to your destination by strange roads OMG really strange..
  7. #47
    Jun 2006
    I am looking for information for gps now. I will read this carefully. Thanks.
    Steven
  8. #48
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by Bugbyte View Post
    N Many GPS's use the serial port, some use the USB port. There may be a driver you have to install. You then configure your Navigation software to let it know where the receiver is and you should be ready to go.
    More detail: Some USB GPS receivers simply route the GPS information over to your PC's com port so the GPS APPEARS to be a serial GPS. They do this by installing a small driver known as a USB-serial port bridge. You can then set the com port by right clicking My Computer-->Properties-->Device Manager. Look under the serial port entry and you'll find the serial port bridge (if it installed correctly). Click on driver and then advanced and you can set the com port to the port you would like. You then set that corresponding serial port in your navigation software and the the receiver should work.
    hey, do you know or have the actual name and link to the USB-serial port bridge???
    i am currently experiencing this problem.
    thanks...
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  9. #49
    Elsewhere
    Prolific
    How about the Wiki?
  10. #50
    Aug 2006
    New Ro, NY
    Quote Originally Posted by DarquePervert View Post
    Prolific
    thanks Dar,
    the site prolific was hosted at is no longer available
    i have found a couple of sites which carry such driver but i'm not sure if it universal to every unit....
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  3. Replies: 8
    Last Post: 03-26-2005, 11:29 AM
  4. GPS dont work with adv Gps setting
    By leckan in forum Map Monkey
    Last Post: 03-06-2005, 12:51 PM
  5. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
