Results 1 to 9 of 9
Thread: Rikaline problems
    Newbie lee03's Avatar
    Feb 2005
    Rikaline problems
    I have tried using my rikaline 6010 with D3, Routis, and mappoint. D3 and routis wont recognize it, and mappoint gives me an error " com port available, but no signal is being recieved. I have only had the gps 3 months. Has anyone else had this problem? It has a battery that is said to recharge itself...could that be the problem?
    Dec 2004
    since you are not getting a signal, are you testing it indoors? You might want to try it outside. Hope that helped a little.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Change the location in the car...
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Feb 2005
    I have tried it using 3 different computers, indoors, outdoors, shifting locations... no luck. When i use mappoint without the gps connected, it gives me the same error.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    are you sure you are using the correct com port in each of your applications?
    Feb 2005
    yep
    FLAC -zip-'s Avatar
    Ontario/Canada
    It should work right off the bat.
    1.Did you install/uninstall the driver, I also downloaded the driver from thier website to make sure it was the most current.
    2.Try different USB ports.
    3.What O/S are you running it on?
    4.Does the light on the puck blink or stay on or no light at all?
    I had no problems with mine at all runs great, perhaps you can get an exchange?
    Sound Stage
    Eclipse|MTX|Infinity
    Feb 2005
    1. yes
    2. did that
    3. XP MCE
    4. Both, when i first plug it in, it is on. Later it will start to blink. ??
    I have already contacted them. It is under warranty so i hope i will get a replacement.
    FLAC -zip-'s Avatar
    Ontario/Canada
    must be defective
    Sound Stage
  1. Replies: 5
    Last Post: 04-09-2005, 06:37 PM
  2. opus problems
    By studmonk3y in forum Power Supplies
    Last Post: 03-29-2005, 05:09 PM
  3. Rikaline 6010 Batt problems
    By naveedh in forum GPS
    Last Post: 02-23-2005, 11:50 AM
  4. My BU303 vs. Rikaline 6010 Review
    By Nico3k in forum The Review Palace
    Last Post: 01-05-2005, 12:42 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
