Results 1 to 10 of 10
Thread: Rikaline 6010 hibernation not working.
    Variable Bitrate skippy911's Avatar
    Feb 2005
    Everytime I have my rikaline plugged in and I try to come out of hibernation the pc locks up. I am using a tc1000. I tried it on my laptop in the house same thing, it locks when i come out of hibernation. If I unplug the gps before I turn it back on same thing. I then tried with the gps not pluged in, put the laptop into hibernation then I brought it back on, and it worked pefect. Please someone help me
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    You really need to make a app to remove the device before you go into hibernation. When you say plugged in.. is this even if its not in use ? ie. not running gps software
    CdR
    Feb 2005
    Quote Originally Posted by CdRsKuLL
    CdR
    Yes even if i start the laptop, never open the gps sofware and then go into hibernate and try to resume, nothing
    Raw Wave justintime's Avatar
    Apr 2005
    I have the same issue. When coming out of hibernation, I can see everything powering up EXCEPT for the monitor (stays 'black'). So I am forced to restart by pressing power button for 6 secs.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Feb 2005
    Thats my exact problem too. I made a little batch file to disable the gps and enable it, just have to work it into my frodo skin now. Anyways here are the lines:
    c:\devcon enable "USB\Vid_067b&Pid_2303"
    c:\devcon disable "USB\Vid_067b&Pid_2303"
    You can get devcon from here:
    http://download.microsoft.com/downlo...240/devcon.exe
    If anyone knows a way to get this gps working properly pleeeeeeeeeeeease tell me
    EDIT: Still not working but getting close. Anyone with scripting knowledge please help
    http://mp3car.com/vbulletin/showthre...199#post520199
    Constant Bitrate Troy McClure's Avatar
    Something like this would drive me crazy and I'd have no other choice but to do a fresh install of the OS, making sure I have the latest BIOS installed. Then load the GPS and see what happens. Most likely it would work. Then you would have to pour through loading drivers on every single piece of hardware you need to install drivers for and see where the conflict is.
    Sucks but it will make you understand where the problem is coming from.
    Troy
    Done!
    If you're into fishing, checkout my website! http://www.pennsylvaniaanglers.com
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by justintime
    that sounds exactly like the problem i experience with standby. hibernate works fine for me, other than the gps not resuming.
    i wonder, based what i've read in this thread, if just immediately killing the power to the usb hub/gps/touchscreen when you turn the engine off - since pc shutdown is delayed (for those using shutdown controllers) - would do the trick.. i'll have to play when i get the car back from the bodyshop.. again..
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    What mines does is I will be using Iguidance and then go into hibernate. When coming out of hibernate Iguidance says something like it can't find the GPS but if I simply click on the connect button it will find it again.
    My USB wifi adapter does similar accept I have to unplug/plug it in for it to work after hibernating.
    Also have to restart girder for it to work.
    Man, this sucky.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Oct 2004
    For those who wish to automate the use of Devcon on hibernate/resume, you may want to check out this thread Run programs on hibernate/suspend and resume!
    Apr 2005
    Falls Church, VA
    Quote Originally Posted by tbird2340
    Sorry for resurecting an old dead thread, but this is exactly the problem I have. I've searched with no sucess, and was wondering if anyone's solved it yet. Thanks,
    Aux
    PCChips M789 v3 w/ Samuel 2000+ S3Vid Lan AC97, 40 GB 7200PRM, 512 DDR266, Xenarc 700YV, PAC AAI-GM9 Headunit Adapter, Sirius Sportster, touchpad mouse input.
  1. Replies: 8
    Last Post: 05-08-2005, 10:52 AM
  2. Replies: 5
    Last Post: 04-09-2005, 05:37 PM
  3. Rikaline 6010 Strange Fault
    By clkraj in forum GPS
    Last Post: 01-22-2005, 08:24 AM
  4. My BU303 vs. Rikaline 6010 Review
    By Nico3k in forum The Review Palace
    Last Post: 01-05-2005, 11:42 AM
  5. Rikaline 6010 & Delmore street atlas USA 2005
    By raymondaecom in forum GPS
    Last Post: 11-30-2004, 01:32 PM
