Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: GPS performance meter on in-car PC
    Jun 2005
    Hi there, great site youve got here.
    Im planning to build my own incar PC, ive got most of it straight in my head but im struggeling on how to add the function of a performance meter to my system for- 0-60 timing, 30-50 timing etc, Quartre mile timing, force and power estimations and so on.
    Will i need a GPS reciever with a higher than standard sample rate?
    Is there any software currently available for this. If not what do i do as i only have limited programming skills.
    I have also been considering linking the system to the cars ECU for live mapping. I would consider upgrading my ECU for this, has anyone had any experience with this and does anyone know of any copmataible aftermarket ECUs
    Another option is connecting the system to the cars air, temp, oil sensors like data logging systems currently avaiblable, does anyone know how this could be done on the go.
    I also have one or two other questions.
    My car-Pc will be based on a laptop which has a pretty poor sound card. Are there any external sound cards available with phono line outs so that i can connect to my current amplifiers.
    Any suggestions for other software would be greatly appreciated, like a good sat nav program with gps locations of speed cameras.
    Seen as ive asked somany questions i will describe what i plan to do incase you are interested.
    The laptop will be hidden in the dash and its power button will be linked to the ignition so that it comes on when the car is started with a manual overide of course.
    The system will mainly be controlled by an 8" touch screen LCD built into the dash but the laptops own screen will disconnected from the laptop and hidden in the passenger side of the dash.
    To the laptop i will add:
    A wi-fi pcmcia card to allow remote access updates and transfers from my home pc
    A GPS reciever for nav, speed cam detection, performance meter
    DAB radio reciver
    High quality external sound card
    Blue tooth dongle for hands free mobile phone functions
    Usb hub built in to the dash for any other connections
    The side of the laptop will be flush with the dash so the dvd player is accesible. As i already have the laptop lieing arround costs ontop of its value are estimated at £260 which seems fair considering all the functions.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    I don't think GPS will work for your purposes. GPS updates too slowly for any kind of precision timing or anything, and it's also not really accurate enough for that stuff. if you want force and power estimations, use an accelerometer. if you want truly accurate 0-60 times and such, add a high-resolution speed sensor to your drivetrain somehow, or tap into the speedo signal if you don't need as high a resolution. either one is going to require a bunch of hardware and software to be made though.
    The easy thing to do would be to just buy one of the available devices that does all that stuff, they're a few hundred bucks but it'll save you a lot of effort...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Jun 2005
    There are stand alone GPS performance meters on the market based on GPS recivers with 200 samples per second. I f i were able to get a PC GPS reciver with that smaple rate then it would be accurate enough but it would only be worth it if there was software about for what i am trying to do.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by evandude
    Ummm... http://www.pistonheads.com/ultima/default.asp?i=9208
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by 0l33l
    oooo I hve been past that airfied a few times (recognise the 747)
    I have seen GPs modules that can run up to 8hz from U-blox but to be hoest an intertial system would be better.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Scouse Monkey
    Well, what we care about is that its possible. Now someone needs to figure out how
    Mar 2004
    Bristol
    you can do it like the U-blox Dr system works by using the VSS speedo pulses calibrated by GPS.
    I.e you monitor the VSS pulses and compare them to the GPS to get calibration for the current car and tyre size, pressure etc etc. Then you use this data to calculate the 0-60 time. This works much faster than GPS can. The u-blox with this feature can only output to the serial port at 1Hz but the DR part worksa t about 40hz.
    Or you can use a 2 DoF accelerometer system to work out the accelerations and thus integrate them to get the speed and distance covered and laterial loads.
    Jun 2005
    Are accelerometers actually that accurate? I cant see how a system based on a mass on the end of a spring can be that good!
    If so are there any accelerometers that could be interfaced with a car pc and give live performance data?
    Mar 2004
    Bristol
    Quote Originally Posted by Timmy C
    ROFL! how do you think missiles and jet planes navigate?
    GPS?
    Inertial systems can be incredibly accurate and fast. Look at the speed of missiles and what if you loose the GPS signal? Aircraft NEVER use GPS as their main for of navigation - it is too risky.
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 08:13 PM
  3. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  4. FS: Complete CAR PC System
    By arise360 in forum Classified Archive
    Last Post: 04-24-2005, 10:17 PM
