I have the same problem with my BUB-303 unless it has a direct line of site with the sky.
Hey I was just wondering.....do alot of you guys have problems with you GPS receiver when its coudy out? Rikaline or not? Cuz whenever there a clouds i can never get a signal....I was wondering if I should get a pharos GPS receiver...ANy input would be great....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Installed.
-GPSSecure- - GPS Tracking
i throw my 6010 on the dash of my van and as long as im outside no matter the weather it locks onto at least 4
In compare to trees, tunnels, buildings, bridges, etc., my Rikaline 6010 hasn't had any problems with clouds. It all really depends on where you hold your receiver.
Agreed. I have my Rikaline outside the vehicle and I ALWAYS have 5 sats at a minimum. I typically have between 8-9.Originally Posted by DJiK
2008 Ford Expedition EL Ltd
Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
Yes, DJiK is absolutely right. The location of your GPS (antenna) is the most important factor. Even an old and not so sensitive receiver may perform better if it is placed on the roof of your car for example. It may easily outperform even the best GPS receiver which is placed in more inferior location.Originally Posted by DJiK
If all else fails, and you still cannot get good reception with your Rikaline 6010, then you could consider upgrading to one of the newest GPS receivers with SiRFstarIII chip. They are more powerful and may even work in some indoor environments. I did an indoor side-by-side test a couple of days ago with GPS mouse by CoPilot (SiRFstarIIe/LP chip) versus my new GPSlim236 by Holux (SiRFstarIII chip). Where the old receiver was useless, the new GPS was tracking with ease:
I am going to mount my 6010 on my front dashboard under the windsheild....I will see what happens then....I dont wanna get a BT receiver cuz i dont wnna have to recharge it all the time...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Clouds have never really affected me, not that I have noticed anyway.
can wait to install my carPC....wanna see how this thing is gonna be
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
prolly going to start it the end of the month....just waiting on the case
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
