Results 1 to 7 of 7
Thread: iGPS-360 (Microsoft GPS)
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    iGPS-360 (Microsoft GPS) mod from USB to RS232
    I am looking to connect the iGPS-360 GPS using a serial port rather then the USB. I have and and have had no luck in finding the cable or the schematics to make one. I tried the CF Adapter Kit for iGPS-360 and it is not compatible with the VIA MII10000 motherboard.
    Has anyone been able to make a cable for this Mouse?
    I sent this to Pharos to see what they say.
    "I purchased the CF Adapter Kit for iGPS-360. I am trying to get away from the USB connection as it is unreliable. The CF adapter uses a non-standard address space using 03F8-0407 for the I/O range instead of the standard 03F8-03FF range. The motherboard I am using uses the space beginning at 0400 for some of the motherboard resources. I cannot get the unit to work correctly. I would like to use a standard 9pin RS232 for the connection to the PC and pull power from the PS2 connection for the 5V. Do you or any third parties make such a cable and if not can you provide the schematics for such a cable.
    Thanks"
    Apr 2005
    Frisco, TX
    OK Here is the response:
    Hello,
    Have you tried following the instructions on our website to fix this problem? We do not have a PS2 connection, and we do not have the access/authority to give pin out information. Is your card bus controller manufactured by Texas Instruments or O2 Macro? If it is then the GPS-CF will not work, only the GPS-360 by itself will work (with the USB cable or Bluetooth). Here is the link to our website http://www.pharosgps.com/support/faq-ht3.htm click on the first option and let us know if you have any other questions
    It looks like I am going to have to figure this one out. I have an idea from some sites I found on on how to do this. I have ordered a MAX232 to convert the TTL levels of the GPS to RS232.
    As soon as I know if it will work or not I will post it.
    I am tired of using USB for critical functions. It is just not as reliable as good old RS232.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by KB5WID
    Too true! Have a look at this - not the same GPS but still may help.
    Earthmate USB to Serial cable
    Apr 2005
    Frisco, TX
    That is close, but, the gps-360 uses TTL level outputs instead of standard RS232 outputs. The cable I ordered converts TTL to standard RS-232 levels. Without it the PC cannot talk to or hear the PC. The voltages are two low.
    The info I am using to do the cable is from the following web sites.
    http://www.msh-tools.com/GBA/gbagps.html
    http://pharosgps.com/support/igps360_spec.htm
    http://groups-beta.google.com/group/...e8e7e6fb7a11db
    The pinout for the GPS-360 is 1. black cable - TXD
    2. brown cable - GND
    3. red cable - RXD
    4. Orange cable - GND
    5. yellow cable - VDD
    6. green cable - GND (seems not connected)
    Remember these are TTL level and not RS-232 standard Levels
    The cable converts 0v & 3.0V or 5v nominal TTL signal to –12v & 12v RS232 serial signal.
    Here is the info on the cable http://www.digitalnemesis.com/catalogue/RLC1/RLC1.htm
    The connector for the GPS is the same as the HP Jordana 560. The connector can be purchased from http://www.gomadic.com/hpjorconplug.html
    Apr 2005
    Frisco, TX
    Got it working. I will post everything in the morning. I now have the Microsoft GPS working directly off of a standard Serial Port.
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
    Apr 2005
    Frisco, TX
    I have desided to scrap the iGPS-360. It is too unreliable. I have figured out that it will not work when it is over 100 F. It is fine for someone who wants to use it with a laptop from time to time. BUt it does not make a good GPS for permanent use. IF someone wants the procedures to make it serial. I did get it to work using a MAX-232 chip.
    I am going with the Axiom Sandpiper II GPS engine board.
    See AXIOM Sandpiper GPS reciever
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    KB5WID, old thread but i have a GPS-360 with a USB cable. I want to mod it to work with my PSP Your links say diferent things. txd and rxd pins 1 and 3. The GBA mod says pin 3 is TXD you post says pin 3 is RXD. Which one is it? I wanted to get it working before my trip but im leaving tomorrow. So i will have to play with it when I get back. Thanks in advance.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  4. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  5. Microsoft S&T05 with GPS MOuse problems
    By arise360 in forum GPS
    Last Post: 11-18-2004, 03:22 PM
