IGuidance all the way. Being in Canada they also have updated the maps. You can configure the size of street names etc with an ini file.
Right now it is the most current map wise, easiest to use, and the most accurate.
My only peeve is the POI's.
If you're referring to the size of the font for street names on the screen then that is an easy fix.Originally Posted by sanbas
Open Notepad.
Input the following:Save the file in the iG directory as theme.ini (Be sure you change the type from Text File to All files so it does not get saved as theme.ini.txt)Code:;street name font size in points @ zoom level STS=15 20 20 20 20 20 20 20 20 20 20
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
Sound StageEclipse|MTX|Infinity
Is there a way to update the POI ? i.e from a CSV file ?
I am nearly done with my install. I cant decide on the navigation software![]()
my friend has a RX330 and God does the nav kick ***. I hope the POI database for IG is as good
is it better on Copilot ?
DEFINATELY don't hold your breathOriginally Posted by anik321
Does anybody have any screenshots of the PC version of IG? I only see the PPC shots on their website.
Check out the software forum, Skinbedder and iGSkinner.Originally Posted by sebberry
Yes indeed it seems that they advertise to the PPC crowd only. I've always wondered why that was the case. As far as I'm concerned there is really no alternative to iGuidance on a PC platform. Nothing comes even close to what iGuidance can do for me. Yet, there is not a screenshot of the PC version on Actually the whole website should be redesigned, because it does disservice to their great product.Originally Posted by sebberry
Is it truely a Win32 Application or is this a PPC -> PC emulation thing?
The iGuidance DVD (or 3 CD's) includes the PPC and also the PC version of the program. You get two for the price of one! You may install it and use it on your laptop or carputer, and also you may have a second copy installed on your PDA. I keep it (as a back up) installed on my PDA Phone and have it with me at all times ;-)
I am about to throw out 100 bucks for either iGuidance or CoPilot 8 (trade in SA 2004). Right now, neither one of them support TMC. Am I right? If no TMC support, I will give that 100 buck for a OBD2 reader. In the mean time, I am okay with Routis and MS ST2005.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
