Results 11 to 20 of 30
Thread: AXIOM Sandpiper GPS reciever
  1. #11
    Jun 2004
    Central California
    @KB5WID: have ever used both serial 1 & 2 on the Axiom SandPiper? Do they both work well?
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
  2. #12
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    I am not using the second port. I only needed the first port. From what I have read the second port will need the MAX232 to convert the levels for it to work.
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
  3. #13
    Jun 2004
    Central California
    Thanks for your reply. The 2nd serial port on my Garmin GPS25 just quit. Contemplating if I should buy the Axiom of eBay. Thanks again.
  4. #14
    Jun 2005
    Quote Originally Posted by KB5WID
    I have it installed now. It worked like a dream.
    Here is the Connections to the PC:
    PC > GPS
    +5 > Pin 1
    +5 > Pin 2
    GND > Pin 10
    Com2:
    Pin2 > Pin 11
    Pin3 > Pin 12
    Pin5 > Pin 13
    Thats it.
    The board is small enought to fit in most cases without issue. I connected to the Com2 header on the VIA MII10000
    The only thing that poped up when I booted the PC was the GPS coming up as a serial mouse.
    The board is a great buy. If you want a GPS and don't need to move it from PC to PC this is what I feel would be a great solution at a cheep price.
    THe UBLOX or PC-11 are also great choices.
    BTW: I got the Active antenna from www.mobilegpsonline.com
    I also bought this GPS, can you tell me how to identify which is pin 1, and which is pin 2, ect??
  5. #15
    Apr 2005
    Frisco, TX
    Sorry I didn't reply sooner. Pin one is the pin with the white square painted on the board.
    All the info on this reciever can be found at http://www.allsurplus.net/Axiom/
  6. #16
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    What do u think about this antenna? do u think it could work with this card?
    http://cell-phone-accessories-wholes...D&ProdID=16824
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  7. #17
    Apr 2005
    Frisco, TX
    That antenna should work without issue. I use Larsen antennas for Ham radio all the time.
  8. #18
    Feb 2004
    Green Bay, WI
    are there any tutorials for wiring this up????
  9. #19
    Apr 2005
    Frisco, TX
    PC > GPS
    +5 > Pin 1
    +5 > Pin 2
    GND > Pin 10
    Com2:/GPS
    Pin2 > Pin 11
    Pin3 > Pin 12
    Pin5 > Pin 13
    That should be all you need to get it to work
  10. #20
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Excuse me boys, I've change my USB GPS mouse whit this Axiom, I've connect an external antenna whic have >28dB of Amplification but I lock poor satellite than the USB receiver.
    Someone have compared the Axiom whit an USB receiver? It's a my problem or it's a Axiom Specification?
    Thanks!
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
  1. Replies: 12
    Last Post: 03-09-2010, 10:16 PM
  2. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  4. Replies: 3
    Last Post: 03-31-2005, 07:17 AM
  5. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
