Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: AXIOM Sandpiper GPS reciever
  1. #21
    Jun 2005
    Quote Originally Posted by slimmegane
    Excuse me boys, I've change my USB GPS mouse whit this Axiom, I've connect an external antenna whic have >28dB of Amplification but I lock poor satellite than the USB receiver.
    Someone have compared the Axiom whit an USB receiver? It's a my problem or it's a Axiom Specification?
    Thanks!
    Same here, the Axiom just not locking the satellites at all. I connect it to com 2 in the motherboard, is that correct? Also, I didn't connect the pin 10 to the ground.
  2. #22
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Hi,
    my problem was in antenna connector, now the Axiom work very well, the only problem is the cold start, about 15, 20 min. but this problem is easy to resolv, is sufficent to leave the +5v and antenna power always connect.
    You must connect the pin 10 to ground and the Com2 is ok to work
    Bye.
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
  3. #23
    Jun 2005
    Hi,
    Bye.
    Thanks for the reply, I'll try to that. How did you get the +5V antenna always connect? "Pin 3, VBAT is not required but highly desirable to connect. If this pin is connected, the receiver will do a warm start and acquire satellite signals very quickly." Do you know how to connect the pin 3 VBAT?
  4. #24
    Feb 2005
    Italy/Lecce
    I've connect the +Vbat at pin 3 of axiom, and -Vbat at GND (pin 11 or later there is one, check first).
    The always on +5volt is because this module more time is fed more satellites it fixes.
  5. #25
    Mar 2005
    Quote Originally Posted by KB5WID View Post
    I have it installed now. It worked like a dream.
    Here is the Connections to the PC:
    PC > GPS
    +5 > Pin 1
    +5 > Pin 2
    GND > Pin 10
    Com2:
    Pin2 > Pin 11
    Pin3 > Pin 12
    Pin5 > Pin 13
    Thats it.
    The board is small enought to fit in most cases without issue. I connected to the Com2 header on the VIA MII10000
    The only thing that poped up when I booted the PC was the GPS coming up as a serial mouse.
    The board is a great buy. If you want a GPS and don't need to move it from PC to PC this is what I feel would be a great solution at a cheep price.
    THe UBLOX or PC-11 are also great choices.
    BTW: I got the Active antenna from www.mobilegpsonline.com
    I finally got around to using this receiver and cannot get anything to work. i also dont have the CD any longer.. so i dont have the test utility program.
    Im curious... do you have to connect the Pin5 on the Com2 to Pin13 on the unit? I use pin 13 (and the gnd side of the battery) and connect it to - on the power supply. i am not getting anything from this...
  6. #26
    May 2005
    Mother Earth
    Quote Originally Posted by chrislloyd View Post
    hello chris i have this reciever connected to my carputer
    the instructions above are correct..I think the problem could be that you dont have the compass( cd software that came with it..) by default this gps reciever is set to sirf mode( the software lets you switch it to nmea which is what iguidance is looking for.)
    also make sure you set the comport to 4800 as no other comport speed settings will work.
    maybe this will help
    http://www.n5na.net/download/axiom_pin_out.pdf
    KIAs can have car pcs too..
  7. #27
    Mar 2005
    thanks for the reply. i thought noone would since the original post was so old. Any idea on where i can get the files from the CD? i looked everywhere... cant find it.
    also, thanks for the tip on the 4800 speed... i had the ports set to 9600.
    i ordered the holux gpslim236 as an alternative. works USB, bluetooth and has the ability for an external antenna.
    thanks again...
  8. #28
    May 2005
    Mother Earth
    thanks again...
    Well I will try and upload the cd tonight to a file download site like megaupload or rapidshare.. I will post the link when i get it done.. hey uh ya want to get rid of that axiom let me know.. pm me..hahaha
  9. #29
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    I use the SIRF Demo software to change the modes and test the unit. http://www.sirf.com/free_demo.html
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
  10. #30
    May 2005
    Mother Earth
    Quote Originally Posted by nigwhyrito View Post
    First i want to appologize it was called conductor... not compass second
    i didnt upload the cd because i found the link here
    http://www.laptop.net.pl/gps_swift/conductor/
  1. Replies: 12
    Last Post: 03-09-2010, 09:16 PM
  2. Replies: 65
    Last Post: 10-13-2009, 06:51 PM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  4. Replies: 3
    Last Post: 03-31-2005, 06:17 AM
  5. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 02:17 PM
