Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 75
Thread: Hacking Iguidance
  1. #11
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    another possible solution would be onscreen character recognition, which is definatly doable, recognizer packs are available all over the place, but this is a little resource intensive
    PC Components:
    My work log
  2. #12
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by Peoples
    i thought about this in the past too (01331 even mentioned this approach at one time), the only problem is when i attempted to have the magnifier directly on top of the "eta" box it basically magnified itself into an infinate loop....so if i cant put the display there, then where would i put it? In that case, if i want to magnify everything including the street your on, the ETA box the next turn distance, and the next turn street name.....and I cant put the boxes overtop of eachother, I think this will make the screen a little cluttered.
    perhaps there a way to tell teh magnifier which window layer to magnify, and also which layer to display the magnification on top of..? or perhaps someone could write this magical app..
  3. #13
    FLAC Marvin Hlavac's Avatar
    May 2005
    Yes, that would be cluttered. In my case I really just want the one item: the ETA box.
    I think the reason why the developers of iGuidance are not responding to this user request is that the size of the ETA box is just fine on the PDA version. Laptop or carputer users are perhaps an insignificant portion of their overall customer base
  4. #14
    Super Moderator xBrady's Avatar
    USA
    currently i'm trying to port the C# program to VB.NET
    Now why would you do such a terrible thing like that?
    Installed.
    -GPSSecure- - GPS Tracking
  5. #15
    Dec 2004
    Maryland
    i've used c# a few times, but i'm not well versed in it......i figure learning to port it from C# to vb will allow me to learn more about c#. C# is pretty simple as it is....ill probably end up writing this whole app in it.
    PC Components:
    My work log
  6. #16
    May 2005
    Again last night I spend some time testing a variety of magnifier software, and it looks like I’ve finally found one that is usable for my needs. I don't know though if it is usable in a touch screen environment.
    You may run more then one instance of it simultaneously, but I'm afraid seeing more then one would be a clutter.
    More info on page 6 of iGuidance Customization Ideas
  7. #17
    Dec 2004
    Maryland
    when actually planning on embedding this into road runner (or any front end app) other consideration would have to come into play. While on different road runner we would have to make this window invisible, or imbed this within the same window as iguidance
    PC Components:
    My work log
  8. #18
    May 2005
    Northeast PA
    I had intensions of doing something very similar to this when I get my carputer started.
    There is a subculture on the internet that uses memory sniffing for games that I was rather active in.
    You may want to check out the guides at http://forever-hacking.com to get ideas about different sniffers, and exe decompilers.
    You also might find some useful information about process injection, and things of that nature at the MacroQuest project. (in their forums)
    Those two sites deal specifically with game hacking, but some of the guides may prove useful to you.
    -Des!
  9. #19
    Raw Wave lostreception's Avatar
    NY
    @martin
    does lens work when IG is not infocus ie on another page like surfing the web etc then if you alt tabed to it would it highlight that same area of pixels of the webbrowser or is it intellegent enough to only highlight from the IG proccess
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  10. #20
    May 2005
    Lens will magnify anything that is within the set area. When using other application, and Lens is bothering you, you may just minimize it. Restore Lens when you want to use iGuidance again.
  1. iGuidance SDK
    By Quattro in forum GPS
    Last Post: 06-23-2006, 08:37 AM
  2. How to make Frodo's RoutisLauncher work with iGuidance
    By dodgetimes2 in forum Software & Software Development
    Last Post: 09-10-2005, 02:47 PM
  3. iGuidance 2.x auto-run shortcut
    By ziggyrama in forum GPS
    Last Post: 08-13-2005, 07:05 PM
  4. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
  5. Launching iGuidance under Media Engine
    By StationRocket in forum GPS
    Last Post: 11-29-2004, 01:56 PM
