Results 1 to 10 of 15
Thread: iGUidance, GPS EMEA stream stalling every few seconds? HELP please!
    Raw Wave justintime's Avatar
    Apr 2005
    iGUidance, GPS NMEA stream stalling every few seconds? HELP please!
    I am having a problem with my GPS setup, and it is driving me crazy. Every few seonds, it appears that the satellite data stream stalls for a while, and then continues. If I open the GPS Info window of my navigation software (iGuidance) I can see it receiving the data stream and updating it every ~ 1 second, but after a few seconds it just stalls (no update on data stream, and also the 'local time' reading stays static) for about 15-20 seconds, and then the whole cycle repeats itself.
    Mind you, all the time it is reading 6/8 satellites, so it is by no means losing GPS signal.
    I am using a Rikaline 6010 USB recevier, but this unit works perfectly on my laptop. So I discarded that as the source of the problem. Must be something with my CarPC... I am using the popular Biostar motherboard with Athlon XP-M 2400+ underclocked by 20%.
    I think the issue is at the USB port (or the virtual commport) level... seems like the port stalls every now and then (not the GPS itself). Any ideas what the issue could be?
    Oh, I also just realized that I am using iGuidance 2.0 on my laptop, and 2.1 on my CarPC. hrmm... could there be an issue with 2.1?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    UPDATE.
    Well, I now know the problem is not iGuidance either, because I ran a test with another GPS utility (Winfast Navigator) and the data stream stalls there too.
    Running this same app on my home PC with the same GPS produces no stalls whatsoever.
    OK, so clearly the issue is with the carputer: either the software, or the PC hardware. Does anybody have any ideas how to determine if it is a software or a hardware issue given the circumstances?
    Any help is appreciated. Very disappointed about this!!!
    2002 Honda CR-V
    Super Moderator xBrady's Avatar
    USA
    Is it just the GPS that is stalling? If you have music playing does that stall too?
    First thing to try would be reinstalling your drivers.
    Installed.
    -GPSSecure- - GPS Tracking
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    sounds like possibly a faulty usb port or bad drivers
    PC Components:
    My work log
    Apr 2005
    Everything continues to operate normally. I can continue using the PC while the GPS stream is 'stalled', music continues playing in the background, etc etc. It doesn't skip a beat in any other area.
    Faulty USB port? Hrmm... I tried both USB ports and get the same result. I also have the USB touchscreen cable connected in these ports, and it operates normally.
    Do you guys think that maybe underclocking the CPU is affecting the timings?
    Any other ideas?
    2002 Honda CR-V
    Dec 2004
    Maryland
    couldnt image that, try updating the gps drivers on there......or comport drivers.....or reinstall windows....or get some windows updatest (are you running sp1?)
    PC Components:
    My work log
    Apr 2005
    Running SP2 with all the latest updates (updated again yesterday to be sure, and it brought back one update)
    I also uninstalled and re-installed the driver (the one that assigns a virtual COM port through USB, whatever it is called). My next step will be to re-install windows, but that would be catastrophic at this point, as I have everything else working the way I want it to, including some neat hacks for startup screens, etc. agh!!!
    2002 Honda CR-V
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    could it be heat? When I have my GPS on the dash it will fail after about 30 minutes. If you have it mounted on the roof of the car is it failing when you are standing still or driving slow and works when you are moving faster.
    Just a thought.
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
    Apr 2005
    No, it can't be heat... I have been testing this on my desk (at home), everything running very cool, same issue.
    I am going to re-install windows and see if the problem is there. If this is the case, I am going to have to RMA this mobo!
    Quote Originally Posted by KB5WID
    Just a thought.
    2002 Honda CR-V
    Apr 2005
    Well crap... I just re-installed windows from scratch, and the problem persists.
    I can only conclude that that one of the two is true:
    a) This is a faulty motherboard, or
    b) There is a compatibility issue with this motherboard and the serial/usb driver of the rikaline 6010
    Can anyone out there confirm success with this combination?
    -Motherboard: Biostar M7NCG400
    -Rikaline 6010 USB GPS mouse
    2002 Honda CR-V
  1. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
  2. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  3. Switch between Frodo player and GPS (IGuidance)?
    By Nanozic in forum FrodoPlayer
    Last Post: 07-12-2004, 02:58 AM
  4. FS: iGuidance GPS Navigation (USB)
    By Blk_G35 in forum Classified Archive
    Last Post: 04-15-2004, 11:40 AM
  5. Replies: 5
    Last Post: 01-19-2004, 01:57 PM
