I have to name the file then click ok.Originally Posted by Wiredwrx
Originally Posted by Cheekz185
You would have to create and AutoIt batch to do it for you.
What happens when you hit record, can you just hit O.K. How does it name the file. I thought it had the date and time. Obviously, the time will change everytime you hit record, so it might be possible that all you need to do is somehow get the O.K. clicked.
Michael
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Nothing comes up as default?
Yeah you are right it already has a name created...Originally Posted by Wiredwrx
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
i believe you are correct; all it would take is ALT-F, R, ENTER keystroked to begin recording. you probably wouldn't even need skinbedder for that unless you wanted to be sneaky about it..Originally Posted by Wiredwrx
So where should i start?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Originally Posted by tj!2k4
As long as the default changes each time, and I believe it does, all you would need would be a couple of keystroked programmed into AutoIt.
Shouldn't be too hard, though I have never used autoit stand alone.
Michael
I dont know how to use AutoIT, I dont realy know how to program....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
so I put this script together for AutoIt and i got it working. Now all i have to do it have the program start minimized.
Code:; ; AutoIt Version: 3.0 ; ;iGuidance ;Run("C:\Program Files\iNav\iGuidance\iGuidance.exe", "C:\Program Files\iNav\iGuidance", @SW_MAXIMIZE) Run("C:\Program Files\iNav\iGuidance\iGuidance.exe", "C:\Program Files\iNav\iGuidance") WinWaitActive("") Send("{ENTER}") Send("{ENTER}") Send("{ALT}") Send("{F}") Send("{R}") Send("{ENTER}")
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
