Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Faulty Unit
  1. #11
    Jan 2005
    yep, set to 4800. what do you have the port set up through windows? i plug the thing in. windows installs it and says its working. i've changed the speed on windows settings to 4800, aswell as trying it at the speed windows configures it at automatically. just a solid green light. freedrive can't find gps. gpsdiag doesn't get any readings.
  2. #12
    FLAC evandude's Avatar
    Mar 2005
    Maine
    what COM port are you selecting in these apps?
    usually they default to COM1, but the GPS receiver generally installs to COM3 or COM5 or something higher up like that. Some GPS software offers the option of "USB" as the COM port selection, but that's not intended for GPS receivers that use COM port emulation (most of the typical GPS mouse ones seem to), so unless you know for sure your receiver is supposed to use that, don't.
    Open up hyperterminal, set it to 4800 8-N-1, and try the available COM ports. Even if you're not getting a signal, you should be getting some data from the GPS unit in hyperterminal... at least that will tell you if the computer can at least communicate with the device.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  3. #13
    Mar 2005
    NYC
    Where is your reciever mounted? When I placed mine INSIDE the car..I got nothing. Once it was outside..I got signal. Note: some tints can cause the gps to not work.
    Another issue you may be having is power. If you do not have enough juice from your PSU, things will malfunction. I learned the hard way.
  4. #14
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Quote Originally Posted by DK888
    Another issue you may be having is power. If you do not have enough juice from your PSU, things with malfunction. I learned the hard way.
    rmember i told u? Cool that you could solve it though. Let me know how everything went. DK> Call me. Did you order the stuff already?
  5. #15
    Mar 2005
    NYC
    Thanks BND..got your number already. Haven't ordered anything. Really tight on the pockets..I'll keep you in mind tho.
  6. #16
    Jan 2005
    no data in hyperterminal, it's dead
  7. #17
    Aug 2004
    Walden, NY
    you can always try a reinstall of OS/Drivers/GPS software. To have a clean start. If you can, you should return it, if not, take it apart, and see if wires are loose or something... sheers
  8. #18
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Can you unplug some other USB devices? It could perhaps, as someone suggested, be a shortage of power to the GPS unit...who knows...
    Unfortuantely, it seems like it just may be defective. I remember my GPS blinking (receiving satellite comm.) even when I didn't have it configured correctly on the software side.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  1. DWW-750J Motorized Screen-Full Review
    By techy101 in forum The Review Palace
    Last Post: 06-27-2005, 06:20 PM
  2. XM-Ready head unit software integration?
    By TaZMaNiaK in forum Software & Software Development
    Last Post: 04-02-2005, 06:23 PM
  3. Remote Head unit Eject Problem FIxed!
    By Sporttracguy in forum Car Audio
    Last Post: 10-02-2004, 02:51 PM
  4. New Sony head unit - botched wiring...
    By SamDude in forum Car Audio
    Last Post: 09-09-2004, 05:21 PM
  5. Review: Kenwood KDC-W6527 Head Unit
    By chewiee in forum The Review Palace
    Last Post: 06-22-2004, 03:14 PM
