Results 21 to 30 of 34
Thread: GPS's that work through windscreens
  1. #21
    Jul 2004
    Santa Barbara, CA
    so if u have the gps on the laptop and its workign fine, then u power on your carpc it drops all signals?
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
  2. #22
    Newbie Muscles's Avatar
    Jul 2005
    Auckland, NZ
    Best way to mount a GPS unit in a car is have the GPS base inside the car and the antenna basicly on the middle top of the roof. This position provides as little metal interference as possible. GPS's work best being as high as possible to avoid the signal coming from the top down from bouncing off the metal.
    I had mine located in the middle just outside and above the front windscreen with the cable going along the top and into the door rubber trim. Works great with usually 12 visible sats showing up most times.
    You need to make sure your antenna is waterproof as well, you can buy them (like mine) which are and also include a magnet at the bottom of the plastic case.
    Makes them very easy to stick on to the top of the roof's. However you might like to secure them on with something else also as magnets tend to lose their power after a while.
    Currently designing electronics and Delphi front end software in create my own carputer.
  3. #23
    Jaz
    Jaz is offline
    Apr 2005
    jrtf83, yes that correct.
    the signal is now acceptable (4 to 5 satellites) when i put a cable choke (think thats right the name) on the usb lead near the computer.
    by cable choke i mean one of those thick metal hoop things.
  4. #24
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Jaz
    Cool. A choke is a great idea. Glad it is helping.
    Can also try shielding the receiver from the computer. You can try using a metal plate under the receiver. That will help shield it. You can also try grouding the PS case. The intereference is most likely coming from the PS (Because it is a switcher) You can also use some aluminum foil to cover the computer case, and see if that helps.
    Michael
  5. #25
    Jaz
    Jaz is offline
    Apr 2005
    the reciever is now on the back window.
    is there anything else which will help? i tried silver foil (this makes it worse oops lol)
    Someone told me that the computer may be using the ground cable to broadcast some sort of signal via the cars ground. And you can fix it by using some device like a diode to only let the ground flow one way???
    interesting point here too, if the pc hasnt turned off yet. my key fob wont lock the car unless im right next to the car, when normally its a gud 15 meters.
  6. #26
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    What did you cover with the aluminum foil?
    That "diode" thing is called a ground loop isolator. It won't hurt, but nto sure it will help.
    I would try a metal plate/shelf under the receiver. Also, where is the carputer? Is it in the trunk? Did you try the receiver in the front, away from the carputer. ( I have seen so many of these posts, I can't keep straight who put what where)
    Good luck.
    Michael
  7. #27
    Jaz
    Jaz is offline
    Apr 2005
    no carputer is in the front, in the glove box. its the cable that seems to be picking up the interferance, not the actual adapter.
    i surrounded the usb cable with foil.
  8. #28
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Time for a new cable. Also, make sure the PS has a good ground.
    I would try and aluminum foil the computer case, not the cable. Especially the PS. Be carefull about shorting anything.
    Michael
  9. #29
    FLAC -zip-'s Avatar
    Ontario/Canada
    If your screen is set to 72Hz or higher lower it to 60Hz. The screen could be interfering with the GPS if it is close enough. Sounds silly but It fixed mine.
    Sound Stage
    Eclipse|MTX|Infinity
  10. #30
    Dec 2006
    I have a 206 and the windscreens are coated with a metal heat-reflecting film. This makes it harder to pick up signals from behind the windscreen. The rear screen will be just as bad with the heated rear windscreen lines.
    According to the manual, there's a section around the rear view mirror (the bit with black dots) that's not coated - stick your GPS receiver / aerial here, it'll work great.
  1. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 02:30 AM
  2. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  3. cannot get lilli touch to work anymore
    By delussional77 in forum LCD/Display
    Last Post: 10-12-2004, 12:52 PM
  4. Has anyone gotten a sproggy to work with EPIA boards?
    By rbarr110 in forum Power Supplies
    Last Post: 05-10-2004, 06:33 PM
  5. Replies: 4
    Last Post: 11-18-2002, 08:59 PM
