Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
Thread: SDAL GPS Map Access Navtech Open Standard Thred
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Right all, there have been a few of us chatting about the open standard from Navtech. This all started from a convo about Alturion and NaviPC which directly uses these disks. BTW These are the same format used in cars today /
    This is the thred - towards the end... post 67 onwards....
    Re - Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ?
    More info
    http://www.navteq.com/sdalformat/
    So, comments from the community please around making a SDK, what format - ie C or VB and any thing else...
    I'm no programmer so I can only make suggestions but if Navipc.com can do it who look to be a 'smaller' company I am sure one of you clever lot ( or a number of ) can do this too... yes if successful you would not need to rely on PC apps developed for this community - more just right the software and buy your own Navtech disk... or if you have one with the car use that one
    Terran
    Mar 2003
    I was surfing around yesterday and found this website ... GgpsDotNet . It basically is an sdk aimed people wishing to design their own gps solution. You can download a 30 day trial and its 153 dollars for a developers license.
    hope this helps
    Jan 2003
    Quote Originally Posted by ldawg221
    hope this helps
    Intresting idea and basically how I see this part ( the map reading part ) working.
    That site seems to just cover the reading of the GPS data and then doing some thing with it...
    Terran ( Although I could be wrong )
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Why not use Delphi?
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by 0l33l
    Why not use Delphi?
    because only you use it.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Quattro
    Not really. There is a frontend made totally in Delphi. What's funny is that 2 OTHER Delphi programmers showed up for the SoCal meet
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    signing up for progress
    Roy
    2005 Range Rover 4.4
    São Paulo, Brazil
    ok, so from gpsdotnet stuff lets see if I understand...
    it is basically a reading and interpretation toolkit for GPS data, doesnt do mapping and/or routing does it? Also it wouldnt be cross-platform as its only designed for MS stuff right?
    I understand this is no small task by ANY measure... and I wasnt belitteling (splng?) the task of writing a frontend, but was merely stating that it might be more efficient to develop the "sdk" (of sorts, that is being discussed here) with some sort of frontend already (I mean the developers will need some framework to test it, it can then be cleaned up and released as well one should think)...
    Yeah, it will take a hell of a long time to dvelop, but it can be very useful, surely something people will pay for (more so than other GPS tools based around crapinator and such)... E-bay has a ton of map dvds 1yr old or so for cheap, so most people would probably be willing to pay or donate to this I'd think...
    Open source might be a good idea in this, I wouldnt mind helping out at some point, but at least for now there would not be any GPS support in terms of maps in my country so I'd be limited in any help I can lend.
    I think it is a large and difficult task, but definitely doable by a community of very motivated and intellignet and good developers like we have seen here on Mp3Car...
    Roy
    Mar 2004
    If the idea is to allow others to make their own custom frontends then there is only two right ways to do it. C or C++.
    Once you get a simple front end for querying the database written in either of these languages then it is almost trivial to make wrappers for almost every other language that anybody would use.
    Also you keep it cross-platform this way, which may not seem important but the Linux/BSD community can put a lot of help behind any OSS project.
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    I know navtech is probably the way to go but if we already own the maps etc from teleatlas (ie. destinator et al) then can't we use our own engine to create a sdk using this
    http://www.na.teleatlas.com/products/formats.html
  1. Replies: 91
    Last Post: 11-07-2006, 04:47 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  3. Replies: 6
    Last Post: 04-01-2005, 01:44 PM
  4. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 02:17 PM
  5. Replies: 0
    Last Post: 03-08-2004, 01:14 PM
