Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Bluetooth or USB GPS receiver?
  1. #11
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I install my USB GPS deeppppp inside the dashboard next to the firewall.
    When was the last time I remove it? Never.
    Well, how often you are going to use GPS on your PDA? If you are going to use it like couple times a month then get the BT.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #12
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Marvin Hlavac - Poss may look at one of those 236's - Do you get the USB cable with it ? Can you place an external areial on it ?
    The reason for this is I because I am thinking of been able to leave the external one on place in the car and been able to take the unit out when needed
    Terran
  3. #13
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    we have a bluetooth that we use for the laptops and pda.
    it is, the biggest pain in the *** to use in the car. ever.
    i will be purchasing a usb soon.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  4. #14
    FLAC Marvin Hlavac's Avatar
    May 2005
    Quote Originally Posted by ccsnet
    Terran
    Sorry for the delay in answering ;-) (We have just moved to a new house and there was verry little time to go on the Internet.)
    1. The USB cable that comes in the package is only good for charging the unit via USB (if that's what you want). To actually use the 236 as a GPS mouse, one needs to order the optional USB cable, which I believe is $19.95.
    2. Yes, it does have external antenna connector. The optional external antenna is also if I recall correctly around $19. I use the external antenna as well.
    I'd recommend ordering the 236, the optional USB cable, and the external antenna all at the same time from one source, to make sure you get the correct items ;-)
  1. BU-303 USB GPS Receiver, Work in sweden?
    By Power_nisse in forum GPS
    Last Post: 07-24-2005, 06:11 PM
  2. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 11:02 AM
  3. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 11:07 AM
  4. HOLUX GM-210 USB GPS Receiver
    By Deadnick in forum GPS
    Last Post: 05-19-2004, 06:02 AM
