Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: turning off IG splash
  1. #11
    Apr 2005
    Queens, New York
    For some reason, after following tj's posts about going into permissions....i get an error when i try to change the value:
    Error Editing Value
    Cannot Edit ShowWarning: Error writing the values new contents
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #12
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    was iguidance running?
    windows version?
    time for bed
    PC Components:
    My work log
  3. #13
    Apr 2005
    Queens, New York
    no iguidance wasnr running, im running XP
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  4. #14
    Constant Bitrate craniumdesigns's Avatar
    Apr 2005
    Hayward, CA
    Quote Originally Posted by Cheekz185
    Error Editing Value
    i had the same problem. first set the regkey value to 0, THEN do all that stuff after to make sure it doesnt get set BACK. if you already set all the advanced settings, switch em back, set it to 0, then switch em back again.
  5. #15
    Apr 2005
    Queens, New York
    Hey i got it to work....All i did was delete ShowWarning. Then it automatically enters another showWarning after starting iG. Then just follow tj's instructions!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  6. #16
    Jul 2005
    anybody ever figure out how to get it so stay at 0. I tried cheeks way but it didn't work. Using 2.1
  7. #17
    Apr 2005
    Hayward, CA
    dude. read this whole thing. look at post #7. there's a link there that tells you how to do it.
  8. #18
    Nov 2005
    the other thread is locked and this seems to be the next best thing to posting where it belongs since it would seem that poeple are still having problems with this.
    FIRST: This was tested with 2.1.3NA. If you have anotehr version I dont know if it will work or not.
    SECOND: This was done on Windows XP, if you have another OS I have no clue how it will function.
    THIRD: When your system doesn't work anymore I am not at fault, you can post to ask for help but I am not promising any.
    I see that alot of people had touble with the whole permissions thing. Others took issue with the fact that IG could not update options anymore. So I made a small batch script that will fix this problem (the nag screen) and will not require you to lock the permissions on your reg. Copy this entire block of code and put it in a file called runIG.bat in the iguidance directory.
    Code:
    reg export hkcu\software\inav\iGuidance inav.reg
    more inav.reg > inav2.reg
    echo "ShowWarning"=dword:00000000 >> inav2.reg
    reg import inav2.reg
    start iGuidance.exe
    Explained: (if you dont care, already get it or just want to try it stop reading here)
    Code:
    This is a command to export a key from the registry, it will write your entire iguidance key set (and subtrees) to the file inav.reg. If that file exists it will be overwritten. If it does not it will be created.
    Code:
    Not sure why but a normal echo would not work on the inav.reg file (probably something to do with CRLF, if you dont know what that is dont worry about it). So I used the MORE command to copy inav.reg to inav2.reg.
    this is probably a good thing because you get to keep the copy of the reg as it was in case a problem occures.
    then the echo which will work on inav2.reg (go figure) adds the line that will "SET" showwarning to 0. If your reg didn't have this key it will add it. Lucky us that windows will accept the same key more than once per reg file which means if it was there then the echo added it a second time. But since the one we added is last it will be the value used to set the key (aka the one that gets to stay).
    Code:
    Loads our corrected reg keys back into the registry.
    Finally:
    Code:
    start iGuidance.exe
    Start is used to prevent the command window from staying open until iGuidance.exe closes.
    If anyone is worried about the 2 files taking up space they are 2k together so get over it.
    I welcome any comments.
    -Bad
  1. Splash Screen (Boot Screen)
    By eCar in forum General MP3Car Discussion
    Last Post: 01-10-2009, 09:45 PM
  2. Remove Splash Screen
    By GARB-E in forum Road Runner
    Last Post: 07-21-2005, 06:06 PM
  3. Zots Skin and Ig. window
    By UM_Fan in forum Road Runner
    Last Post: 07-02-2005, 08:14 PM
  4. Problems turning my carputer on
    By nappyjim in forum Power Supplies
    Last Post: 05-04-2005, 10:21 PM
  5. my computer keeps turning on by itself?
    By rep999 in forum Off Topic
    Last Post: 06-11-2001, 06:09 PM
