Results 1 to 6 of 6
Thread: GPS not found with MM, but ok with MS streets?
    Nov 2004
    Northern VA
    For seemly no reason whatsoever, Map Monkey can't seem to find my GPS reciever (the one that came with Streets and trips) - most of the time. Every once in a while it will find it just fine. But Streets and Trips finds it pretty much every time.
    When I open MM, it won't say "attempting to reconnect GPS", if I go to GPS status, it says "GPS not found."
    I've noticed that MM is more likely to find the GPS if I open streets and trips, let it find the GPS, clost S&T and then open MM.
    This is a somewhat new problem - Any ideas????
    May 2005
    I know that the S/T gps works with iguidance so it isn't "locked" to that app.... hmmm, can't help you there unfortunately
    Nov 2004
    Northern VA
    Quote Originally Posted by sebberry
    Yeah, for a while everything was working fine - I really can't pin it to one thing or the other. Though I've noticed the problem seems to persist no matter if I use MM or Freedrive
    May 2005
    I have kinda the same problem, it works with Autoroute 2005 and freedrive, but not mapmonkey??
    Nov 2004
    Northern VA
    This is really strange - does anyone have any ideas???
    Nov 2004
    Northern VA
    bumpy bump
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. No initial focus on embedded MS Streets
    By HyperSprite in forum RR Skins
    Last Post: 06-09-2005, 01:41 PM
  3. BU-303 with MS Streets and Trips
    By devin98 in forum GPS
    Last Post: 05-15-2005, 06:20 PM
  4. errors on the homepage
    By alti in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-14-2005, 10:26 PM
  5. Replies: 19
    Last Post: 11-19-2002, 07:37 AM
