Results 1 to 10 of 10
Thread: How could I make my GPS turn on my Radar detector only while speeding?
    Aug 2005
    KC
    Sorry if this is a repeated question, but here goes:
    My Valentine 1 (V1) goes off with false alarms all of the time. I get so sick of it that I don't even listen to it much, which is bad.
    I've noticed that alot of the GPS systems have an indicator that will pop up if you are traveling over the speed limit. If there could be a way to have the computer running the GPS to be connected to a servo that would only turn on the radar detector while going over the speed limit, it would cut out alot of the false alarms.
    I can forsee two complaints here:
    1) every time you go over the speed limit, the detector will make the announcement noise that it does when it powers up.
    2) You may want to know when the cops are around even when you aren't speeding...but to me, this would be a fair trade to get rid of all of the false alarms.
    Does anyone have any ideas here?
    Or can you direct me to where someone has already done this...believe me, I've looked.
    Newbie Payback001's Avatar
    Aug 2005
    West Plam Beach
    ... that would be cool but haven't here anthing like that . Have you upgrade your V1, that should help with the false alarms.
    Aug 2005
    KC
    yes, I just did and it still goes off constantly.
    I must be living in the wrong city.
    May 2005
    This doesnt sound very feasible. Youd have to find a database file which matches the speed limit to streets. Youd then have to somehow integrate that into the GPS or make a program that uses the GPS position... Good luck!
    Aug 2005
    KC
    actually no...
    It seem as though some gps systems "know" the speed limits of most streets.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Most GPS systems are programmed with the general type of street you're on..that works with the 'preferred route' stuff. It knows a highway is a highway, residential street is residential..but it might not know specifically what the speed is, just the type of street, and it uses that to factor the 'quickest' or 'shortest' time.
    Sep 2005
    I have a StealthOne from www.jaricdesign.com. It has the feature of auto-muting if the car is over a set speed. So my V1 mutes automatically if an alert is present and I am going less than 40mph. It works awesome. It would be cool if we could pickup the speed from the OBD-II or GPS software and have it do the same. The speed limit for a particular street doesn't matter to me, just that I hear the alert when I'm going really fast and not when I am going slow. The majority of my alerts come from near malls and stores where the speed limit is usually 35mph or so. Works great for me.
    Jon
    Jul 2004
    Santa Barbara, CA
    what you'd need isnt a servo but a relay, you'd use power from a pin from a serial connection i'd imagine, but you'd need some pretty good programming skills i'd think.
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    Jul 2004
    Santa Barbara, CA
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The V1 interfaces by zPilot and jombonzzz can mute. So all you really need is software now. You could mute or have special sounds on the PC when you are speeding, so you hear the falses plus more annoying sounds when you should be really scared.
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. Replies: 16
    Last Post: 09-05-2007, 04:19 PM
  3. Different GPS Voice's Project!
    By bimmercore in forum GPS
    Last Post: 10-10-2006, 04:59 AM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 07:31 PM
  5. gps lose signe when turn on ftf
    By rent_a_hero in forum GPS
    Last Post: 12-17-2003, 10:27 AM
