Impressive. I'm gonna ask the obivous question. Where to download? :)
Printable View
This feature would be very cool. We are using IGuidance as our in-car interface and Google Maps to track vechiles from the web.
The google Maps API has spawned so many cool projects. One example:
An app that monitors gas prices and plots them on a map. Based on price the user can work out the cheapest place to fill up.
If we could pull this info already available on the webserver and import it into IGuidiance think of the hacks that could be made.
Menu -> display options -> custom poi -> allQuote:
Originally Posted by CavityCr33p
Why not ditch Iguidance then?Quote:
Originally Posted by 12Vsystems
Destinator has an SDK and the forum already has several members working on pretty cool applications. I'm using cdrskull's Free Drive and it is quite good! I think he has some plans up his sleeve to incorporate some of these types of features...it already has the ability to import speed camera locations (used often in Europe)
I have spent a lot of time working with destinators SDK, we developed our own app only to run into the dll expiry problem. We were give the new SDK which is different from the orginal and required us to re-write code that we never even had a chance to release.
IGuidance looks nice, has better routing and is cheaper. With the modifcations made by some of the people here it is the best GPS solution I've seen.
Couldnt have said it better myself. Put the emphasis on ROUTING though and it blows destinator awayQuote:
I didn't know that anyone had modified the Iguidance software. What modifications are you referring to?Quote:
Pretty much everything. You can essentially make iguidance look however you want with programs like igskinner, skinbedder, and igmod. There are also zoom tools. Then if you really wanna have some fun you can take a reshacker and customize it further.
Has anyone released a "package" of some sort, like mapmonkey or Freedrive, except using Iguidance?Quote:
Originally Posted by Sonicxtacy02
no.. unfortunately due to lack of sdk there probably wont ever be a "package of modifications similar to MM and FD.
