Results 1 to 4 of 4
Thread: MS Streets & Trips 2005 $9.99 (OEM)
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Found this over at Fatwallet (credit to joshcloud9 @ Fatwallet.com), thought it is a good deal for those interested in this software. Note that it is JUST the software (no GPS) and is OEM. I bought the full version with the GPS, short of it is that the GPS sux, the software has some useful features, but is not the best for simple navigation, but good for planning - also had some quirks in the routes it chose (had me going around a non-existent area of road construction).
    http://www.shop.com/op/~Microsoft_St...-prod-10549709
    It is offered through Shop.com, but it is really sold by Softwareoutlet.com, item 0228.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Low Bitrate widower's Avatar
    Jun 2005
    Quote Originally Posted by Supermike
    I'm surprised that you don't like the gps. It's a pharos gps repackaged by ms. I've never had problems with mine. I do find it aquires slow when I'm using the CF adaptor but on my laptop using usb, it works like a charm.
    I do have to say though, I'm disapointed with the bluetooth adaptor. When using my pocketPc, if I turn off the ppc while connected bluetooth to the gps, the pocketPc never trully turns off. I end up with a dead battery. You have to disconnect from bluetooth before power off.
    May 2004
    AZ
    The main problems I have with it are having to re-connect when the PC goes to sleep and I was not able to get it working with Destinator (did not try that hard though). It does work, but is not as trouble free as some - I think my next GPS will be a serial version.
    http://www.eff.org/
    Jun 2005
    I've seen other threads where people are having problems with any usb gps after hybernate. The successfull guys are using some command line tools to intercept, disable the peripheral, then hybernate. Sorry, I don't recall the threads but a search for interceptor, hibernate trigger, devCon, may help find the threads.
  1. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  2. BU-303 with MS Streets and Trips
    By devin98 in forum GPS
    Last Post: 05-15-2005, 06:20 PM
  3. can map monkey work with MS streets and trips?
    By jay_tu in forum Map Monkey
    Last Post: 05-08-2005, 09:46 PM
  4. MS Streets and Trips 2005 with BU-303
    By mjking816 in forum GPS
    Last Post: 12-16-2004, 06:49 PM
  5. Replies: 2
    Last Post: 08-15-2004, 05:49 PM
