Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: iGuidance Font Size Fix summary thread
  1. #21
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I have iGuidance 2.1NA and put the pre-prepared theme.ini and also the ctheme.ini (which should be the one required) found through this thread in the iGuidance directory where the .exe was to be foun and....nothing changed. I edited the file to increase the road name font size further and....nothing changed.
    I love IG but find the itty bitty text on the road names unreadable...can someone help me here please?
  2. #22
    FLAC Marvin Hlavac's Avatar
    May 2005
    Hi Pip, the font is changeable in most versions, including yours. Start from the beginning, step-by-step: >click here<
  3. #23
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by Marvin Hlavac
    Ah, thanks for that. I created a ctheme.ini (I have 2.1) and adjusted the font size alone...seems to have worked. Must be something funky with the .ini file I downloaded.
    EDIT: Actually...it was me....still had a .txt extension....duh!
  4. #24
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Please make this a sticky!
    Thanks.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  5. #25
    Jan 2006
    Could someone please PM Iguidance 2.1.3 patch and theme.ini file. I am having dificulty downloading it from Inav. email is jnyer27@gmail.com
    Thanks in advance
  6. #26
    Mar 2006
    Next turn text bar
    Is possible to make the top display next turn text bar or text front size display bigger?
  7. #27
    May 2005
    Search for iGzoom by 0 l 3 3 l
  8. #28
    Mar 2006
    does IGzoom works on WM2003?
  9. #29
    May 2005
    I suspect it doesn't. It was designed for a common CarPC (WinXP,etc).
  10. #30
    Mar 2006
    Thanks Marvin, so any idea to make the text biger? biger text easy to read when you drive and more safety.please help me out.thanks
  1. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 07:07 PM
  2. Replies: 3
    Last Post: 08-22-2003, 02:03 PM
  3. Street Atlas Deluxe font size
    By rdliou in forum General Hardware Discussion
    Last Post: 03-17-2002, 11:46 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 07:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 04:49 PM
