iGuidance Font Size Fix summary thread
First of all, this is a summary of the Iguidance 2.0 font size is killing me thread.
Because no one read the damn thread & just posted "Ooooo, send it to me too!!!" it turned from a great thread about optimization to 28 pages of garbage.
Sorry, last outburst from me.
I'm going to summarize the info and then hopefully open it up to further development! All this info is from many helpful members like liquid_smoke, veetid, Nanozic, frodo, Quattro, Marvin Hlavac, and all the others I forgot. None is mine, I'm just summarizing their most excellent work.
The basic theory is that there is an undocumented ini file that you can make, that iGuidance will read. Make this file with your settings, and you can change a great many things such as font text size, road colors, road width, etc. GPSPassion has a great thread that is also dedicated to development on this front. There's some great background info & even more tips.
If you happen to see another file floating around called theme2.ini, the only difference between theme & theme2 is the amount of settings in it. Theme2 has settings which allow you to change geo-features such as body of water, airport, land, etc. iGuidance will not read these files. You need to copy their contents into the original theme.ini file.
The developers of iGuidance have asked not to put the file on forums, so I'm not posting it. So please don't ask me or anyone else for it. You can make your own using info in this post. You have been summarily warned.
While the contents of the file may remain the same, regardless of version, the filename must change for different versions.
Routis: sorry, none of this will work for you. You folks are SOL.
iguidance v1.1: feature not implimented. No ini file will work.
iguidance v2.0: theme.ini *
iguidance v2.0.2: ctheme.ini
iguidance v2.1: ctheme.ini **
iguidance v2.1.1: theme.ini
iguidance v2.1.2: theme.ini
iguidance v2.2: ?
* If you have registered your copy of iGuidance, inavcorp has a download patch for you.
** If you have 2.1, remove these 2 lines from ctheme.ini lest the program crashes:
; map background color (day night)
MBC=255,249,230 0,0,0
Here are step by step instructions on how to get this going:
You won't have a theme.ini in the default directory. To make your own theme.ini file do the following:
0. Make sure you have the "hide file extensions" unchecked through File Explorer
1. Go to this post: http://www.mp3car.com/vbulletin/show...0&postcount=74
2. Select the contents of the post from the first ; to the last 0
3. Copy the current selection (Edit-> Copy or Ctrl + C)
4. Open notepad and paste from clipboard (Edit -> Paste or Ctrl + V)
5. Save File As theme.ini in the same directory as iguidance.exe. (Be sure to use the appropriate name for your version of iGuidance)
If you just want to download the files,
0. Visit this post: http://www.mp3car.com/vbulletin/show...&postcount=423
1. Save File As theme.ini in the same directory as iguidance.exe. (Be sure to use the appropriate name for your version of iGuidance)
If you want a very simple file that simply increases street names so they're legible,
1. Copy the following 2 lines (Edit-> Copy or Ctrl + C):
; street name font size in points @ zoom level
STS=22 22 22 22 22 22 22 22 22 22 22
2. Open notepad and paste from clipboard (Edit -> Paste or Ctrl + V)
3. Save File As theme.ini in the same directory as iguidance.exe. (Be sure to use the appropriate name for your version of iGuidance)
Other notes: Apparently in 2.1, if the color scheme is white or black, you can't change the local road colors. You can in the other 2 schemes though.
http://www.mp3car.com/vbulletin/gps/46838-iguidance-sdk.html for the iGuidance SDK thread started by Quattro
http://www.gpspassion.com/forumsen/t...TOPIC_ID=28166 More customization ideas.
In a similar vein, if you guys want to make all the windows look more authentic (more 'car pc navigator' like) you can use reshacker (find it via Google), and then do the following to remove the menu bars. (The window's menu bar used to drag windows... who needs that?)
1) Select the dialog
2) Right click dialog window, and select EDIT DIALOG from the contextual menu.
3) On the bottom left, there is a list. Some items will be highlighted in yellow. Find WS_DLGFRAME and highlight it.
4) Save compile etc.
You can do this for every dialog. They look much more authentic WITHOUT the windows menu bar!
See pic here: http://www.mp3car.com/vbulletin/show...&postcount=271
or...
just get 0l33l's iGLaunch.
Also, you can use a magnifier program together to see some of the items bigger too, like the ETA in the bottom right corner. Along with hotkey support (the inventor uses a keyboard instead of a touchscreen) he wrote a program called iGkeys. You can find it here.
gZoom (also known as iGZoom ) is also available. It's here.
Sonicxtacy02 devised a method of incorporating zoom into Roadrunner, which you can read about here.
