Results 1 to 8 of 8
Thread: Destinator 3 won't load maps
    Aug 2005
    I've just got the Destinator 3 SDK and also the pocket pc version of it.
    I've installed the app and have it working on my pc and I have dragged the maps into the Destinator folder. Everytime I go to switch a map I get the message
    Your map is not registered. Please use another map.
    What have I done wrong.
    To get the maps on the pc I just dragged them straight from the disc.
    Aug 2005
    Do i have to install it on my pda first, activate the maps and then copy the maps back across to the pc?
    May 2005
    Derbyshire, UK
    What app ?? Map monkey or freedrive ??
    You need the correct dll to be able to use larger maps I think.
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    Aug 2005
    I'm using mapmonkey and using the DestDLL.dll file
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    the DestDLL.dll file wont support large maps. Also Powerloc have stopped giving the .dll that does out due to the fact the PN sdk is going to be released soon. Try installing FreeDrive, then trying mapmonkey again
    CdR
    Aug 2005
    Thanks very much CdRsKuLL.
    I installed the latest version of Map Monkey and then tried it and had no problems whatsoever.
    Thanks for your help br0
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by CdRsKuLL
    CdR
    I thought the PN SDK was already released?
    Feb 2004
    Manchester
    yeah it is but its that buggy it wont even start up !.. As soon as I have working version I will be sending it u m8 :-)
  1. FS: M10000, Morex 3688, 40GB 2.5", SLOT Load dvd/cdrw, 512mb ram
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 07-13-2006, 10:53 AM
  2. FS: Destinator Maps, Motherboard, Memory and more
    By fromplanetbob in forum Classified Archive
    Last Post: 07-16-2005, 02:21 PM
  3. Adding maps ??
    By cnfusion in forum Map Monkey
    Last Post: 07-15-2005, 07:43 PM
  4. maps maps maps
    By Negr0n in forum GPS
    Last Post: 03-13-2005, 06:14 PM
  5. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 06:57 PM
