WHere is the actual antenna mounted? It's gotta be directly under your window or mounted outside of your car so it is in direct SIGHT of the sky above. Any opaque obstruction (especially a car's metal body) will keep your GPS from getting a signal. If that doesn't work (as you mentioned there was NO light activity) then you have a defective GPS or USB port. Try a different USB port, and if all else fails, you need a new gps mouse![]()
LinkBack URL
About LinkBacks
