Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: What can compare to my Acura navi???
  1. #11
    FLAC -zip-'s Avatar
    Ontario/Canada
    Use your Wifi - log onto the companies website Blockbuster, banks, Home Depot you name it.
    Copy address , past into IGuidance DONE.
    IGuidance is fine for me works great. As far as being off 100 feet I remember seeing an issue on these boards a while ago.
    I have never had that problem with Iguidance, works great.
    Sound Stage
    Eclipse|MTX|Infinity
  2. #12
    Spring Hill, Florida
    Quote Originally Posted by parvo99
    Also, when using Iguidance, my location is very accurate if I"m stationary, but when I'm driving, the lag causes me to be off by over 100feet sometimes. It's not real bad, but when I'm in an area where streets are close together, sometimes it's dificult to judge which street I need to turn on. Is there a way to adjust for the lag, or increase the refresh rate?
    Thanks.
    I had a similar problem and I changed the location of the GPS received (previously on dash) now sits on decklid and works remarkably well
    2005 Black Chevy Impala
  3. #13
    Jul 2005
    Thanks for the tip. I'll try that, but I'm not sure it will work. It's not that the GPS is inaccurate, it's that the position of the car isn't updated fast enough. When I'm moving at say highway speeds, I may be off by 200 feet, but when I come to a stop, my location is dead on.
  4. #14
    Aug 2005
    Jersey
    I thought it was cuz your CPU isn't fast enuf. I'm running my carpc off my laptop which is a 2.4 GHz P4, and I don't have any problems. I plan to have around the same speed once I actaully build the "desktop" type car pc.
  5. #15
    Jul 2005
    I'm also using a 2.4ghz P4, so I don't think it's a CPU issue. So, when you're traveling at say 70mph on the freeway, and you pass an overpass, on the map you pass it at the same time? In real life, when I pass the overpass, on the map, I"m still a couple hundered feet away from it.
  6. #16
    Aug 2005
    Jersey
    mine lag behind once in a while, but for the most part its pretty much right on the money. I think GPS placement also makes a difference. I used to put it on my dash and now its on my trunk... its more accurate on my trunk and it also gets more signal.
  7. #17
    Aug 2005
    What type of hardware/software are these nav systems using? Some smart people should figure out how to use them on a Carputer.
  1. 2004 Acura TL w\ OEM Navi
    By pimpmode in forum Fabrication
    Last Post: 09-27-2005, 01:38 PM
  2. install oem navi in a g35c w/o navi?
    By isaldjgxi in forum Newbie
    Last Post: 07-06-2005, 12:30 PM
  3. 2003 Acura CL-PC
    By juve021 in forum Show off your project
    Last Post: 04-10-2005, 12:15 PM
  4. Which OS, and which Navi Program
    By Wiredwrx in forum Software & Software Development
    Last Post: 01-14-2005, 12:34 PM
  5. 2k2 Acura TL with navi
    By threepointtwo in forum Newbie
    Last Post: 07-22-2004, 04:13 PM
