Results 1 to 8 of 8
Thread: Problem with loading maps
    Mar 2005
    Hi Guys,
    I am hoping someone can help me with a problem with Map Monkey.
    I have Map monkey running the Australia Maps Q2 2003 with No problems.
    Now recently I have got a copy of the latest Australian Destinator maps Q2 2005. I put the map in the destinator directory but when I try to swap to the Australia Map It wont let me physically select it. So then I click on the icon " Switch Maps" and it comes up with a error message saying this is not registered and dosent even load the aussie map.
    Please can someone help me
    Much Appreciated.
    Cheers Guys
    Doddyz
    Mar 2005
    reg
    Fixed All Working
    8inch Touchscreen, P3 667 mhz, 256mb ram, 120 gig hdd, Gps Mouse, Destinator, Frodoplayer, Oziexplorer, Reverse Infrared Camera, Dc Converter, 4x 75watt rms amp.
    Newbie Mr_PHOENIX's Avatar
    Feb 2006
    Hi doddyz
    I need your help, i have same problem as well but i try, i can't fix it. how you fix it?
    Jan 2006
    i have same problem too, help!
    Jan 2006
    Erie, Pennsylvania
    I hate when people post a problem, get a solution, and not share it. I don't even have this issue, but dude, you need to post that **** up...
    Jan 2006
    i have also solved the prob now, PM me if your struggling or email @ bubba_2k3@hotmail.com
    Nov 2006
    Hello ,
    I can not figure out why I can't run the Australian Map ( Version 2005.Q2.3446 ) on the Map Monkey. I can't switch to Australian Map. And if I delete the default London map and replace it with the Australian Map. It tells me it's not Registered.
    Can you please help me out ?
    Regards
    Kevin
    Jan 2006
    email me at the above address and ill try and sort it for you
  1. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
  2. join destinator maps
    By lysienne in forum Map Monkey
    Last Post: 07-05-2005, 04:07 PM
  3. How to install both US and Europe maps?
    By MacSuzuki in forum Map Monkey
    Last Post: 06-25-2005, 04:37 AM
  4. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  5. Replies: 0
    Last Post: 06-11-2004, 10:56 AM
