Results 1 to 10 of 11
Thread: Gps Performance Meter?
    Sep 2005
    Does anyone know of any software that is capable of capturing 0-60, 0-100 or 1/4 mile times from a GPS. Is the GPS data accurate enough??
    .....Sorry just found the other posts.
    Jul 2004
    Santa Barbara, CA
    link to the other posts?
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    Sep 2005
    Quote Originally Posted by jrtf83
    sorry:links
    Here is an option
    Not sure if you want to spend money or not but I use this:
    http://laplogger.com/software.shtml
    The serial interface plugs into the ODB2 sensor on the car.
    Works great
    Jason
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    GPS for performance measurement? Useless cuz most GPS receiver/software update like one a second or so. Maybe OBD2 but not GPS.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Proscan v2 has Dyno & Drag strip recording facilities but will need an ELM compatible OBDII Serial Interface card to enable it to work on a CarPC or Laptop...
    Other than that seach Ebay for a G-Tech Performance Meter. They usually sell for about 45 (rrp 149). This is a standalone box that will monitor its accelerometers, and IIRC GPS position, to produce timing figures. Or it may just be the more expensive unit they make that does GPS. There is enough info here for you to find out more...
    HTH
    John
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    GPS simply is not accurate enough for us to use for 0-60 times. It can refresh fast enough, it's just usually not more accurate than +/- 15 feet (on a good day.)
    Accuracy is restricted by the US Government.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Aug 2004
    On the edge!
    Racelogic Vbox used super accurate GPS & accelerometers to provide a cars timing figures. It is extremely accurate and is used by most motoring magazines to get performance figures. It uses military grade GPS receivers.
    It can be done - But the Vbox is about 5k IIRC
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by EBFoxbat
    The government turned off the Selective Availability restriction in 2000. Accuracy now only depends on the number of satellites being tracked and the capability of the receiver. The +/- 15 feet accuracy is in latitude/longitude, not speed which the gps computes separately. The problem in using this for 0-60 timing is the update rate of the receiver.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    WAAS installations will improve accuracy. I'd think you could get a reasonably but not absolutely, accurate estimation by doing a series of runs.
    The problem is going to be the update rate of the GPS receiver. It's too slow to be useful.
    Want to:
  1. Replies: 4
    Last Post: 07-19-2006, 06:57 AM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 02:59 AM
  3. Replies: 6
    Last Post: 02-04-2006, 09:22 AM
  4. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 12:11 PM
  5. Replies: 8
    Last Post: 03-26-2005, 10:29 AM
