Results 1 to 6 of 6
Thread: USB micro GPS antennas?
    Sep 2005
    Has anyone here seen a usb micro gps antenna? I used to have a pioneer avicn1 and the gps antenna was only a inch square. Most of the usb antennas I've seen look they would be 2-3 inches square. The one that came with the pioneer was great because it looked almost identical to the Terk xmicro for xm.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    If you're asking about just the antenna part, then this Micro Mouse is 1.3 x 1.0 inches. It's not usb because there's no receiver to it. You have to plug the antenna into a gps receiver. I don't think there are any usb gps mice (antenna + receiver) that are quite this small.
    Sep 2005
    OK next question. Where would I find a gps receiver that has a usb port?
    Jun 2003
    Chester Springs, PA
    I'm not sure I'm understanding you. You want to plug a usb device into a gps receiver??? GPS receivers can plug into usb ports, they don't have usb ports.
    Sep 2005
    What I mean't was a gps receiver that plugs into a usb port that will accept a micro gps antenna. The idea is to have navigation without having a huge chunk of junk of a gps antenna on a car. I don't think my clients will want a 2 or 3 inch square gps antenna on their expensive car.
    ddn
    ddn is offline
    Dec 2004
    So get a micro mouse antenna, and an OEM GPS module which and a USB-RS232 adapter.
    http://www.dellanave.com/projects/carpc/oncore_gps.php
    Done.
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  3. earthmate usb gps with MS Streets&Trips?
    By liquid_smoke in forum GPS
    Last Post: 11-27-2004, 09:45 PM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. FS: Group Buy USB GPS Receiver (BU-303)
    By Toups in forum Classified Archive
    Last Post: 03-15-2004, 07:32 PM
