They use gyroscopes and a speed sensor from the ECU AFAIK
And also AFAIK, there are none that interface with computers unfortunately
edit: The features called dead reckoning BTW
I know some cars keep track of the location (for instance in downtown areas where the signal might be lost) using accelerometers (I assume).
Are there any serial/usb receivers that can do this?
Yeah, I thought that would be the case. If they were available though I don't think they'd be cheap.Originally Posted by aoLhaTer
On a similar topic, which receivers are better at keeping a signal?
I found this
http://www.whitebream.com/p801.shtml
So theres possible development but no product
I was just driving around SF last week and I kept loosing signal in certain spots because of the buildings. So I as well would like a dead reckoning USB/RS232 reciever
I currently use a Garmin OEM 15L
Its quite a good little reciever and can be even better depending on what antenna you buy. Requires a little wire splicing but its easy if youre familiar with just basic electronics
As, aoLhaTer stated its called Dead-Reckoning. I believe jcdillin and Scouce are working on something like it for there cars. Here's a link that might help.
http://www.u-blox.com/products/Produ...3-X-04001).pdf
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Interesting link.
That's pretty much the problem I was considering. I'm not so much worried about losing signal in SF's downtown (as I know it like the back of my hand), but more about being in a similar location that I don't know.
Hmm, so you can add a seperate antenna to the GPS receiver? I am considering using a BMW, Audi or HOnda/Acura type little antenna that goes on the roof of the car instead of just putting the receiver on the rear deck.
Any antennas you can recommend?
arg.... stupid pdf load times...
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
I guess you've missed this thread:
Ublox module , help needed!
Laidback already has it working and jsdillin is working on the design for a daughterboard to the gyro and interfacing the ublox module.
/M
