I get the same thing, but I just ignored the warning. MAKE SURE that your GPS unit is in a good position to receive signals and you should see your current position on the map, regardless of the warnings MapMonkey is giving.
If you are experimenting indoors and are not getting a good signal then the error message can make you think that it's a configuration problem.
Maybe your problem is different, but it worked for me :-)
LinkBack URL
About LinkBacks
