sorry 2.1.1NA and it does not work
OK, I can't understand why it won't wirj on 2.1.1NA I will pull that patch for now, until I can determine what the %$#@ is going on!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
CRAP... I double checked and Im a 2.1NA gaaaahhhhhhhh this is drivin me nuts
Maybe thats why its not working, cause you used my byte number for 2.1.1
2005.5 VW Jetta 2.5L, 1957 VW Beetle Custom
Previously Owned: 2000 VW Beetle TDI, 1982 VW Vanagon Westfalia, 1971 VW Super Beetle
My VW Jetta mk5 Carputer
frodoplayer.com
mk5 OEM NAV Skin - Frodo - In Progress
OK, so looks like fixerofallthing is the only one with a true 2.1.1NA? All others are full of $%$$##! and using 2.1NA rotf!
Will work it out with fixerofallthing to see what is going on. Let's not let this thread grow uselessly until I get a while to look into this. One way or another, we will get this out there for you all.
2002 Honda CR-V
Alright. Updated first post again. The new 2.1.1NA patch should work for those with that version.
If you have 2.1.1NA and it does not work, it means you screwed up with the file at some point in time (ex.: you tried modifying it with ResHacker or something). You MUST use a clean fresh original copy of the exe files for this to work.
Users with 2.1NA will have to wait.
2002 Honda CR-V
SNIFF SNIFF :'( lol ITS WORTH EVERY SECCOND!!!Users with 2.1NA will have to wait.
Damn i have 2.1na. is there a way to upgrade to 2.1.1??
if you dont double post and reach a low bitrate status you will have access to it under your mp3car download section :-)
