Page 21 of 31 FirstFirst ... 1112131415161718192021222324252627282930 ... LastLast
Results 201 to 210 of 308
Thread: iGuidance Button modification (Centrafuse style)
  1. #201
    Aug 2005
    Quote Originally Posted by justintime
    No patch for 2.1.3 planned. Sorry.
    much sadness fills the land
    Cheers
    Aaron
  2. #202
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    question...
    Where can i find de size of the Menu botton? i found the string to remove the tekst, but cannot find the touch size...
    PLEASE HELP!!!
    www.superchargedmiata.net - all about roadster lifestyle
  3. #203
    Raw Wave tj!2k4's Avatar
    Oct 2004
    justintime - i finally got around to trying this.. and all i can say is WOW.
    awesome job man..
  4. #204
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by lazy_g
    question...
    PLEASE HELP!!!
    I could not find it either. Wish I could, because size is kinda small on that MENU button
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #205
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    JIT: Cool. I installed the patch. I have a request though... It would be cool to have a program that patched .bmp files to any version of iGuidance. Then people would be able to make an iGuidance skin (as a collection of properly named BMP files) and your program could apply an directory of .BMP files to any version of iGuidance.
    Then I could include a patcher with my SKINbedder - iGSKIN that was similar to your patcher, but with all the on-map buttons being replaced by single-pixel BMPs.
  6. #206
    Apr 2005
    RPM_VRD: I think there is a command line utility that can do that. Problem is, it takes more than just replacing the BMPS. All the dialogs need new positions/dimensions for the buttons!
    2002 Honda CR-V
  7. #207
    Nov 2004
    L.A.
    True, but you could calculate that from the size of the image and knowing any one of the 4 corners (and/or by adding up the total size of all buttons in a dialog). ...or I suppose in a INI, XML, .REG, or other database along with the BMPs.
  8. #208
    Apr 2005
    RPM not quite that easy (at least not that I know!)
    2002 Honda CR-V
  9. #209
    Aug 2005
    Hey, idea...
    If I send you the 2.1.3 exe do you think you could adapt a patch for it?
    Cheers
    Aaron
  10. #210
    Nov 2004
    L.A.
    Is there more to the 2.1.3 upgrade than just the exe? It would be hard to patch if you couldn't run it to test.
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  2. Minimize Button For Centrafuse 1.1?
    By Chita79 in forum Centrafuse
    Last Post: 08-17-2005, 01:08 AM
  3. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 10:17 AM
  4. Toshiba Satellite Pro power button modification
    By NRGZ28 in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:07 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
