this is actually kinda cool, but I would still need the OSK to be bigger if I was to use this for daily use... do you plan do do that or is that not possible?
If you build a patcher to take 2.1 to a 2.1.2NA, then the patcher will contain code from v 2.1.2NA. This is really not very different from distributin v 2.1.2NA, so really should not be done. It is OK to distribute a patcher than will ONLY contain new images etc, but if it contains original iGuidance code then I can see how they would balk at the idea.
Maybe there is a way to export the new resources (icons, windows, etc) and import them into 2.1 to create a patch. Will find out.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
PURDooM,
When I'm using your latest preview of IGMod, the regular IGuidance menus often come up. For example, when confirming destinations after entering information on the OSK, I must hit the tiny "nav" button on the regular IGuidance menu. If that's the way IGMod is going to remain, it would be great if those menus were bigger. Perhaps, though, this is just one of the changes you haven't yet gotten to in the new version.
Kevin
Thats because its not done yet. Its a preview![]()
The plan is to have no iguidance menus visible at all in the final product. I am pretty close but the POI menu generator is messing up a bit for me, and when integrated in an frontend the zoomed results list only shows up every other time. So a couple bugs to work out and ill get you a new release.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
That's what I had assumed, but there was a side of me wondering if you had decided to go back to a few select IGuidance menus for speed purposes.
This is getting off topic
Hey, anyone with a good sense of design send me (or point me towards) a goos set of icons for the main menu please? SOmething large and clean. And they all have to be consistent in design.
2002 Honda CR-V
Why dont you just extract the original and add the button background to the image and re insert...
because they are fugly!
Originally Posted by m2x0p9x
2002 Honda CR-V
I updated the first post with new screenshot of Main Menu.
As it turned out, the dimensions of the icons are FIXED. (dammit). So I could only place a 34x34 icon ion there. It would have lookd awesome in full size, but it is not possible.
2002 Honda CR-V
Dude Thas ****in Bomb Assssss!!! I Like It I Want That ****!!
