Results 1 to 5 of 5
Thread: Rikaline 6010 Issues
    Jun 2005
    Phoenix, AZ
    I have been using the Rikaline 6010 GPS receiver for a few months without any trouble. Starting a few weeks ago it has been acting very strange. Sometimes it will take 10 minutes or so to get a lock, and I haven't had it lock on to more than 5 at once.
    Does anyone have any ideas for me to try? Anyone else have such difficulties with the particular receiver? I've been searching the forums on this issue and couldn't find any related posts specific to this receiver. On the other hand, the thread for the BU303 describing an issue thought to be caused by a rechargable battery inside the unit describes symptoms very similar to what I am experiancing. You can view that thread here.
    Any input would be wonderful.
    Scott
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    I have read similar posts, but never could find a battery in my 6010. Have you unplugged the receiver lately? I know sometimes my USB devices act goofy if I plug them into a different port. For instance, my touchscreen wouldn't work when I unknowingly switched ports with my Rikaline...try a different USB port.
    Another issue could be power. USB devices are typically powered off the USB itself unless you have an external power supply, which the 6010 does not. Have you added anything to your system that is drawing more power from the PSU? USB devices react oddly when they don't have neough juice.
    Hope this helps. I can't really think of anything else.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    Jun 2005
    Phoenix, AZ
    I removed the battery last night. It is inside the metal casing when you open it up. I had to remove a lot of solder to get inside. After removing the battery, the unit would not work at all. I may have made a mistake when I was soldering though so I'll have to check that. Good point about the power [ITL], but I don't think that's it as my setup has not changed much.
    So, I'm considering purchasing a new receiver if I really can't get this one fixed. It looks like the BU-353 is real solid.
    Scott
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Mine works great...describe your setup
    500+ full albums
    4,000+ video games
    old carPC
    Jun 2005
    Phoenix, AZ
    You are using the Rikaline? I have it setup with my 600Mhz PII laptop. The thing is, it used to work fine.
    Scott
  1. Replies: 7
    Last Post: 07-06-2005, 10:54 PM
  2. Replies: 8
    Last Post: 05-08-2005, 11:52 AM
  3. Replies: 5
    Last Post: 04-09-2005, 06:37 PM
  4. Rikaline 6010 Strange Fault
    By clkraj in forum GPS
    Last Post: 01-22-2005, 09:24 AM
  5. My BU303 vs. Rikaline 6010 Review
    By Nico3k in forum The Review Palace
    Last Post: 01-05-2005, 12:42 PM
