Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
Thread: New THEME.INI available now :)
  1. #41
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    If I remeber correctly, the backgrounds are an image resource. You need to replace the with your background of choice.
  2. #42
    Newbie dragonjo8's Avatar
    Jun 2005
    Alta Loma, CA
    Ding..Ding...Ding...Ding...Ding....you are correct!! Thank you for your help!!!
  3. #43
    Raw Wave justintime's Avatar
    Apr 2005
    Like I said before, if the patcher doesn't apply on your exe, you are not using a 'clean' version. You would have needed to re-install from original CD, and then apply the patch.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #44
    Jun 2005
    Alta Loma, CA
    Umm...actually I am using a 'clean' executable...the executable for version 2.1.3, which your patch does not recognize. This is why I had asked you if you could post all the images (not just the turn direction images) from your patch. I was trying to avoid doing an extra step (extracting the images from your patched executable) however, you probably did not see my request as the images were not posted. Rather than wait (or nag you with another request) I just bit the bullet and did it all. A PITA, but I'm happy with the result.
  5. #45
    Apr 2005
    Quote Originally Posted by dragonjo8
    iGMod appears to work, however, justintime's Big Button patch does not. I had to do the whole thing myself (which was a major PITA, BTW).
    Dargon, to be clear... I busted my *** making these patchers.
    Your statement above is very misleading... you're saying the patcher does not work. Well, there is not a patcher for v 2.1.3, but that is a totally differenty story.
    2002 Honda CR-V
  6. #46
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Were not really in competition. And besides our respective mods are mostly to suit our needs and not the community needs. We were just generous enough to share our results with the community.
    Edit: I believe we are offtopic, lets keep discussion on the theme.ini plzkthx
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  7. #47
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Map background color does not seem to work on 2.1.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  8. #48
    Jun 2005
    Alta Loma, CA
    justintime:
    I did not intend to leave the impression your patch doesn't work. It obviously does, just not for 2.1.3, which I realize was never designed to do so. I was merely pointing this out for anyone with 2.1.3 who was thinking of trying it. After doing the image replacement and dialog changes myself, I can totally appreciate how much *** you busted to create a patch. Even before I undertook the task myself, I assumed it must be a lot of work (which is why I never requested you make a patch for 2.1.3). Having completed a working version, I completely understand why you would choose not to create another patch. You have done more than anyone could have hoped for with the 6 you have already created. It truly is A LOT of work!!
    PURDooM:
    I was not trying to create a competitive atmosphere here (even though you once joked about competition in another thread). There is definitely room for both mods. I think there are a lot of people who will probably use both (i.e. your OSK and justintime's images).
    I, for one, am very grateful (I did attempt to send you a "donation" via credit card) for all the hard work people like you and justintime share with the less, technically, gifted.
    Sorry if this reply is off topic. I just felt I needed to address the last 2 posts.
    BTW...PM me with an address and I'll send you a check to replace the rejected credit card funds. That goes for you too, justintime. Even though I didn't use a patch for my current version of iGuidance, I am still using your graphics, aren't I?
  1. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  2. Iguidance 2.0 font size is killing me
    By djtrickee in forum GPS
    Last Post: 08-26-2005, 08:51 AM
  3. Replies: 3
    Last Post: 04-18-2005, 03:44 AM
  4. iGuidance theme.ini
    By schillrw in forum GPS
    Last Post: 04-09-2005, 03:40 AM
  5. i need iguidance v2.0 theme.ini
    By i3igmind in forum GPS
    Last Post: 03-27-2005, 02:48 PM
