Thats a peoples question I think. He got the farthest in tapping the iguidance memory.
He hasn't been around here latley...
I should learn how to use that gamehacker program. I suck at reading live memory.
First I want to thank you guys for your efforts on making ig very touch screen friendly for usI have a question to ask since you both have seemed to have gotton further then any of us for hacking Ig I was wondering if you guys have found out where the next turn info comes from so maybe we can get it working like freedrive does in RR so if where in other skins like audio we would still be able to see the next turn info. Do you guys think this is possible ?
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
I sent him a pm
the problem with the memory solution is that it seems to hop around as time goes on, and I havent been able to figure out why. I havent really touched the project since I got really frustrated. Everything worked for about a month at the same memory location. Then after a so much time, the memory location would move, sometimes as little as 2 bytes away...but enough to render a program useless. I thought this was a fluke, because the memory stayed static on another machine I had....but then this machine's location changed as well.....unless someone can figure out what is causing the memory location to change.
PC Components:
My work log
Well, given we don't ever know where the location is in memory is there a way we can search memory for some patterns? Like the words "turn left" or something?Originally Posted by Peoples
