Page 18 of 23 FirstFirst ... 891011121314151617181920212223 LastLast
Results 171 to 180 of 223
Thread: Google Earth GPS Tracking Solution
  1. #171
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Does everyone here already know about this:
    http://sites.onlinenw.com/goops/goops.php
  2. #172
    Variable Bitrate davidhite's Avatar
    Feb 2006
    Quote Originally Posted by RPM_VR4
    There's more info here GooPs Real-time GPS Tracking and Navigation for Google Earth -Version 2.5.13 Released
  3. #173
    Feb 2006
    Oregon, USA
    The "helicopter effect" happens with some GPS receivers. It's due to the bearing that's being reported by your GPS receiver changing while you are stationary. I am currently working on a feature that lets you turn on "smart following" which basically means it will only listen to bearing changes if your current speed is over X MPH (probably would want to set it to, say, 1 MPH or 2 MPH). This means that while you are stopped at a stoplight, if your GPS receiver is jumping position enough for it to think you're changing bearings, Earth Bridge will just ignore those bearing changes until you've started moving significantly enough for a valid bearing to be taken. That will eliminate the helicopter effect.
    It's not easy to explain, so I hope I've done a decent enough job here. If all I've done is confuse you, let me know and I'll take another stab at it.
  4. #174
    Feb 2006
    You have to change the Tilt/Zoom through nemaGE or Earth-Bridge, you cannot do it using the normal Google Earth controls.
    The spinning thing is probably due to signals from your GPS unit. It is probably reporting the change in heading as you see it. It sounds like a pretty cool feature though...
    Hey Dylan: Can you make EB so that whenever you are stopped (and showing the flag icon), the map slowly rotates clockwise? LOL.
    DiNASTY: Which one of the 2 are you using? Try using the other one .
    For the navigation issue you might want to give GooPs a try. I designed it so it doesn't interfere with the native Google Earth navigation while tracking. When you change the range, tilt, pan, whatever in Google Earth it stays.
  5. #175
    Nov 2004
    L.A.
    It all looks good. I might prefer the sub-menus horizontal, not sure though. I don't fully understand what all the left icons are supposed to do though.
    This is what I have named them in the INI file:
    Actions=Route,Play,Car,Home,M,North,a
    I got all the right menu working. I should be able to upload a GE skin tonight. It won't handle EarthBridge/nemaGE yet, it will just be for Google Earth on a PC with no GPS (for easier development).
    Bump.
    What do you envision each of your buttons doing Mercury7?
  6. #176
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    Hmmm...
    2002 Grand Am progress :
    [] - 80%
    ...complete setup, but still need to make the install cleaner
  7. #177
    Mar 2005
    By the way, if you guys did not notice a lot of google earth textures are misalligned by 10-70feet. It is somewhat annoying b/c the GPS signal quality no longer much matters. In the areas I have been in WW actually has better quality in terms of alignment, but GE has better quality textures (which is what they really are). And of course GE has roads, and more importantly to you guys it has all the internet features which make it amazing like the traffic update. I am still frustrated with the misalignment of textures though b/c it makes it appear I am driving through peoples back yards and parking lots etc...This bug is noticed elsewhere as well (on other forums). Mayhaps I will just have to buy delorme's thing or something instead
  8. #178
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Quote Originally Posted by sxott
    Well I am in boston and to be honest I was amazed how presice my position was on the map! I am exactly on the road 99% of the times! Well some times i am in the wrong side of the road which wories me a bit but in general no misallignment at all. What about you guys? Sxott where are you located? maybe it has to do with your locaton or maybe your GPS has a constant error, could need a factory reset, I have seen it happen before
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5 SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  9. #179
    Feb 2006
    Oregon, USA
    I live in Oregon and most of the time the positioning is quite accurate, but there are certain areas where all the texture data is shifted west by about 20-50 feet. It should be noted, though, that all the road overlay data is very, very accurate. So in the areas where the texturing is a tad bit off, I trust the road overlay. But again, most of the time it isn't a problem.
  10. #180
    Mar 2005
    I am in Texas though not in a large metroplex perhaps that is why. I know my GPS is correct b/c as I said I have a handheld GPS that agrees, WW shows it correcly, MS streets and trips shows it correctly, on GE is incorrect. If you look on the forum linked to above that originally had the development for the GE plugin several posters there have the same issue. It is googles fault though, but I am sure it will be fixed sometime soon.
  1. Google GPS on the horizon?
    By Prindle19 in forum GPS
    Last Post: 12-23-2005, 10:42 PM
  2. GPS vehicle tracking, any advise ?
    By paulfromholland in forum GPS
    Last Post: 07-01-2005, 04:42 AM
  3. Tracking a GPS Reciever
    By TheBlackJester in forum GPS
    Last Post: 04-10-2005, 12:41 AM
  4. Replies: 1
    Last Post: 12-11-2003, 05:49 PM
  5. A simple GPS solution
    By C4M in forum GPS
    Last Post: 08-25-2002, 09:57 AM
