Page 9 of 23 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 223
Thread: Google Earth GPS Tracking Solution
  1. #81
    Jan 2006
    Maryland
    can anyone recommend a good GPS reciever for this purpose?
  2. #82
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    Quote Originally Posted by Crazy A
    I have a Globalsat BU-353 usb gps reciever and it worked amazing with GE. The only prob I had was that there weren't high-res photos for my town. I ended up sticking with M$ $treets and Trips '06. But if you live in an area that has really high res photos of your town/city, you'll love it.
    bu-353:
  3. #83
    Jan 2006
    Maryland
    To Jack Man
    You are the man, thanks for the tip
  4. #84
    Nov 2004
    Motodude, this is Great!!
    One question though: I was monitoring the KML file, and it seems that you update it roughly each 5 seconds, no matter what number I put in the GE settings option.
    Is there a reason for this, and could you put the update frequency of the file as an option in the KML export option screen? I'd love to refresh the file each seconds, giving it a "smoother ride" ;-)
    Thanks, and keep up the good work!
    André
  5. #85
    Jan 2006
    Quote Originally Posted by MotoDude
    Good idea, but if all you want to do is cache the data in your area, you can do this by creating a tour in GE.
    If you have GE Plus, you can draw paths anywhere and fly along the paths. If you have GE free you can put a collection of placemarks into a folder and fly the tour from placemark to placemark. Put a bunch of placemarks into a folder and fly the whole folder. The order is top to bottom, as you ordered the placemarks in the folder.
    It takes a lot of experimentation to get the results you would expect. At first you will experience "bunny-hopping" from placemak to placemark. This can be fixed by going to Tools -- Options -- Control -- Advanced. Set the Driving Directions Tour Options for a shallower camera tilt angle and longer range, and change the speed. Then set up a new tour and see if it's how you like it. It all takes a while to get the hang of.
    Is this kind of what your after? It does get the data in your cache. You may also want to set your cache size to the maximum of 2GB. I've found that 2GB covers a pretty good sized area, but it does depend on the quality of the images in your area.
    I tried this in the free one. Does not seem to work as expected and changing the flying specs only work for driving direction. I am attempting to write a script that generates nicely placed placements over an area so that playing a tour produce the results we are looking for, for cache a city. I will make the input a Lat and Lon as the center and a width and height that you want to cache in miles and it will generate an xml file or as google earth calls it a kml file that you can load into GE and then play the tour.
  6. #86
    May 2005
    So, there is still no way to get GE working dloading first yor city maps before you start driving?
  7. #87
    Dec 2005
    Wrong format!
    Hey! I am trying to nmeaGE, but the program seems to create kmls in a wrong format. Saw a nother guy having the same probs. on this link: http://bbs.keyhole.com/ubb/showflat....0/fpart/3/vc/1
    He had xp with german language/charset, I am running xp with norwegian language. Could this be the problem?
    Heres some of his post:
    ...the KML file has a wrong format.
    Instead of the following lines
    <longitude>12.6254483333333</longitude>
    <latitude>42.5243733333333</latitude>
    <coordinates>12.6254483333333,42.5243733333333</coordinates>
    the KML file contains these lines:
    <longitude>12,6257416666667</longitude>
    <latitude>42,52467</latitude>
    <coordinates>12,6257416666667,42,52467</coordinates>
    If you import the second KML file into Google Earth, longitude becomes "12" and latitude becomes "6257416666667".
  8. #88
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    its the decimal point plague all over again
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  9. #89
    May 2005
    Quote Originally Posted by Bravellir
    Hi Bravellir!
    As you said I realized the problem... you are right.
    bmw318ISCoupe, what you have to do is to replace all the decimal points with commas...
    Eduardovdr
  10. #90
    moahdib's Avatar
    Jul 2000
    Switch to English XP
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  1. Google GPS on the horizon?
    By Prindle19 in forum GPS
    Last Post: 12-23-2005, 10:42 PM
  2. GPS vehicle tracking, any advise ?
    By paulfromholland in forum GPS
    Last Post: 07-01-2005, 04:42 AM
  3. Tracking a GPS Reciever
    By TheBlackJester in forum GPS
    Last Post: 04-10-2005, 12:41 AM
  4. Replies: 1
    Last Post: 12-11-2003, 05:49 PM
  5. A simple GPS solution
    By C4M in forum GPS
    Last Post: 08-25-2002, 09:57 AM
