Results 1 to 7 of 7
Thread: Tracking problem
    Nov 2005
    Tracking problem
    hi, i have buy a holux dm-210 gps antenna. but i take almust 20 min to track my place. and somtime the computer cant fint the gps antenna.. sombody ther can help me?
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    I'm not familiar with the holux antenna's, but it doesn't seem right that you have to wait for 20 mins to start it up!! I guess this is a common thing with some people.. Anyways, if you can't find the antenna, maybe it's set to the wrong com port in the computer? I don't know what software you're using, but when I search my com ports in streets and trips it finds it everytime. Maybe you're just comming out of hibernation if you're using it on a laptop computer and it is having problems that way.. but I don't know, 20 mins to boot it up seems kinda crazy?? Maybe it's just a faulty mouse? my bu-353 takes about 3 seconds to boot up,,, maybe check into that mouse?
    - JackMan
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    make sure it's not being seen as a serial mouse
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    What kind of vehicle? Where is the mouse located? Do you have tint?
    Metallic tint, including that on some factory windscreens will interfere with GPS signal reception.
    Could also be your location, you sometimes come across weird 'black-spots'. My GPS mouse usually takes like 40-50 seconds to get a lock...went to a store in another part of Denver and the GPS wouldn't get a lock until after I'd left.
    Could also be a bad GPS mouse...more info please.
    Nov 2005
    Quote Originally Posted by pip
    The care is a Mazda Miata and The gps-mouse is in the midt of the frontwindov.. i have no tint. i have try to connect my laptop to the gps in the car whit out mouving the mouse. and i take about 3 sec to get a lock then.. can it be mu carpc in som kind?
    Aug 2004
    right click on my computer >> properties >> hardware >> device manager, and look for a microsoft serial mouse. If you find it, right click on it and disable it, rather than deleting it.
    If its not that, try using the test program, gpsinfo, that came on the driver disk with your mouse. Watch the data feed and see if it 'cuts out', so to speak. There you can see the satellites and see if the thing is working.
    I've used dozens of those receivers and have never had any issues.
    let us know if you have any luck
    Nov 2005
    Quote Originally Posted by Vinister
    all taht are in order.. but i have now discover that the gps antenna dos't power op somtimes.. can it be that it is cold?
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  3. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  4. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 09:27 PM
  5. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
