Results 1 to 8 of 8
Thread: A Nutty GPS Reciever, thinks im not where i am?
    Jaz
    Jaz is offline
    Apr 2005
    Hi
    i was driving up the M6 last night and all of a sudden the GPS reciever went insane, it started thinking i was in random places, doing random speeds. map monkey kept recconecting to the gps reciever, and it would get the speed right for 2seconds then drop to zero again.
    I tried rebooting pc etc, but it didnt help, eventually it corrected itself (as i reached my destination, typical...) but it would be handy to know if anyones experienced this before, and what causes it, and if ive got a faulty reciever?
    doesnt fill me with confidence if this happens all the time
    its a fortuna usb gps adapter.
    thanks
    Oct 2005
    Same Thing
    Hay I had the same thing for the first time last night to.
    Mine kept saying I was the other side of the river Thames than I actully was.
    Maybe there was something going on with the network.
    Or maybe the Thames is Haunted to!!!!!
    Erggh
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by deanogps
    Erggh
    Most definately.
    Aug 2004
    I think sometimes if only 1 satellite is sending garbage data it will pull your position over to the wrong place, but still close to where you are. I've had this happen a few times. Sometimes the 'track roads' feature in gps programs snap you over to the completely wrong road.
    On the other hand look at the new google earth with gps and it seems to show you your precise position within a foot or so.
    Jaz
    Jaz is offline
    Apr 2005
    so its possible it was a satellite and not my equipment?
    i did have lock on around 6-8 satellites...
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    I'm thinking it wasn't the satellites messing up. 6-8 satellites should be more than enough to figure out where you are.. maybe it just had a computer fart? Maybe try a fresh install of the drivers..
    FLAC Marvin Hlavac's Avatar
    May 2005
    I'd suspect the receiver, or the software, or the receiver connector not plugged in properly, or some interference, or anything else you can think of, but very unlikely it was due to the actual GPS network.
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. AXIOM Sandpiper GPS reciever
    By nigwhyrito in forum GPS
    Last Post: 03-13-2008, 10:36 PM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  4. Replies: 6
    Last Post: 03-07-2005, 12:27 PM
  5. How about THIS GPS Reciever??
    By ppgt94 in forum GPS
    Last Post: 04-15-2002, 08:26 PM
